Display plugin version?
  • Display plugin version?
    I don't seem to see any function in HS API to pass plugin version to HS for display?
    But somehow HS does display plugin versions? Only for local plugins by reading assembly version directly?
    In HS2 there was a function to return your plugin version back to HS whereas that went with HS3 and as you say it gets the assembly version from the exe. I can't say I ever remember it working remotely or not and it may be that it is just not passed back down the communications path whereas on a local plugin it can read it direct from the file.
    My Plugins:
    Yeelight 3P | Nanoleaf 3P
      That is correctly HS loads the plugin twice. First time into a temp app domain to get the version and call a few functions like the registration type and name. It then unloads the plugin, and then runs it as a separate process.
