"Select Port" appears in plugin management when plugin HSCOMPort returns false.
  • alexbk66
    [Update] I fixed this problem in my plugin by changing Target framework to .NET Framework 4.5 from default 4.6.1
  • alexbk66
    [Update] I renamed the plugin, assembly and namespace, still same problem. So must be sone other reason...
    [Update] Ok, found it, it was in Hspi.dll, not my HSPI_xxx.exe So this works now, but another problem:
    Now it shows "INFO: Plugin start is pending".
    What now?
  • "Select Port" appears in plugin management when plugin HSCOMPort returns false.
    I was testing my plugin remotely, so didn't notice that HSCOMPort was returning true. Now I tried to copy plugin to HS server, so "Select Port" appeared.
    So I changed HSCOMPort to return false, recompiled and reinstalled. But "Select Port" didn't go away...
    What's the ...?
    Click image for larger version  Name:	Capture.PNG Views:	1 Size:	41.5 KB ID:	1275210
