Plugin API change in 3.0.0.13
This is a sticky topic.
  • Plugin API change in 3.0.0.13
    We had to make an API change the plugin API for Linux support. InitIO has one parameter which is the port number for plugins that use a serial port and have HS3 give them the port number. Under Linux, the port is a string and can be "COM1", or "TTY1", etc. HS3 will now give the user a list of available COM ports that the system provides. So to support this we had to change the port parameter to a string.
    This change breaks the API so all existing plugins will need to be changed. All you need to do is change this parameter from an integer to a string. Even if you are not using the parameter, you still need to make this change.
    I would suggest that in your install.txt file you add the following line at the top of the file:
    ,[CHECKVERSION],3.0.0.13
    If you are using the HomeSeer supplied serial port paramter and are using the .NET serial port class, you should set the supplied parameter to the "PortName" property in the SerialPort class when you open the port.
    This will ensure that no one can use the plugin in older builds of HS3.
    The API change is in build 3.0.0.13. You can download this build from here for testing:
    ftp://homeseer.com/updates/Beta/SetupHS3_3_0_0_13.exe
    LOL NOOOOOOOO
    That is a lot of plugins to change for me.
    PLEASE NOTE
    I would recommend anyone using my plugins stay on 3.0.0.12 that does not want to be dead in the water until I get to this.
    Cheers,
    Bob
      Our plan is to not release 3.0.0.13 until all the plugins in the updater are updated. So by the time anyone sees the update message, the plugins will be safe to use.
        Originally posted by Blade View Post
        LOL NOOOOOOOO
        PLEASE NOTE
        GET CRACKIN!!!!!!!!!!!
          So, how do I test my plugin with v13 if it won't be available until I've tested my plugin with v13?
          tenholde
          tenholde
            Heh... the chicken and egg...
            Should just be a change from integer to string?
            Sent from my SCH-R970X using Tapatalk HD
              still has to be tested
              tenholde
                Rich is going to post a private build to developers only.
                Cheers,
                Bob
                  I have updated the original post with the link to the test build.
                    All of mine are updated and in the HS3 updater
                    They will only install for HS3 3.0.0.13 and higher
                    Cheers,
                    Bob
                      Done for AirplaySpeak.
                        took a quick gander...
                        installed .13...
                        then went to update plugins and just different issues... couldnt get plugins page to load right.. then wouldnt install plugins.. lunch is over so back to work...
                        so I reverted back.. so guess Ill wait it out some.. thought id give a quick try and my first thoughts...
                          The .13 build is for testing your own plugins only. Most of the plugins in the updater currently will not work in .13. Ours will be updated shortly, but for now, don't load any of them and you cannot use any that you already have installed.
                          installed .13...
                            understood..but still gave it a try
                              And when is Z-Wave plugin updated
