Set Timer or Counter value in a script?
  • Set Timer or Counter value in a script?
    I didn't see this in the HS Scripting index. I am wondering how I can reset, resume or set a timer's time? How about counters?
    I would like to do this as well.
    Bill
      Try.
      hs.TimerReset(TimerName As string)
      hs.TimerValue(TimerName As string)
      hs.CounterDecrement(CounterName As string)
      hs.CounterIncrement(CounterName As string)
      hs.CounterReset(CounterName As string)
      hs.CounterValue(CounterName As string)
      Greig.
      Zwave = Z-Stick, 3xHSM100 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
      Scripts =
      Various
        Have a read of this thread, I use it as a "kitchen timer" and it works well.
        http://board.homeseer.com/showthread.php?t=155895
        Might give you some ideas.
        Last edited by Gogs; August 19th, 2013, 11:10 AM. Reason: Forgot to include the link
        HomeSeer 3 V 3.0.0.318 with ALEXA (AKA Amazon Echo)
        BL Radar V2.0.217; BLRF V2.0.85.0; HS Touch V3.0.0.1034 X10 V3.0.0.42; PHLocation V3.0.0.38; Zwave V3.0.1.110; X10 V3.0.0.42
        BLBackup V2.0.39;ImperiHome3.0.0.20 All on Windows XP Pro
          Originally posted by enigmatheatre View Post
          Try.
          Greig.
          Thanks. That helps a lot. But what about stop, start and set for timers?
          Bill
            Bill
            Bill,
            Good question!
            I have not found anything that will do this yet.
            Greig
            Scripts =
            Various
              Thanks for the responses everyone. Much appreciated.
                Sorry, in earlier post forgot to include the link.
                  If those calls don't exist, hopefully they will add them. In the meantime I am triggering manual events to start and stop timers.
                  Bill
                    Try.
                    Greig.
                    I have checked the documentation again, nothing on this area reached documentation yet. Also I want to use the counterincrement function, but this function does not do anything yet as far I can check..
                    I HST will document these functions soon, because I feel a bit left in de dark here?
                    Wim
                    -- Wim
                      I'm using timers for recurring events. They work fine, but I have seen that if a timing cycle is missed for whatever reason, they never retrigger until the the timer is manually reset. Should I create an event to restart the timers every day? Or is there a better way to handle this?
                      Steve Q
                      Sent from my iPad using Tapatalk HD
                        How about creating a new timer from script?
                        or starting timer and stopping timer?
                        I see that you can create a new global variable for example in a script, but I don't see anything in the docs about creating a new timer.
                        Is this possible?
                          Is this possible?
                          No, no and no I am afraid, although I believe hs.timerreset will reset and start a timer again (potential bug). The request for this sort of thing has been around for some time - http://bugzilla.homeseer.com/bugzill...ug.cgi?id=1222
                          My Plugins:
                          Yeelight 3P | Nanoleaf 3P
                            Thanks for the reply.
                            I am hitting dead ends everywhere I go with stuff that micasaverde did with ease. Very dissapointed at the moment.
