Call a plugin function from HS Touch
  • Call a plugin function from HS Touch
    I have a plugin function that works correctly if called from a script. The syntax used in the vb.net script is:
    hs.PluginFunction("MyPlugin", "", "MyFunction", {"Param A", "Param B", 0})
    This works great.
    I would like to call the same function from HS Touch. With HS2 all that was needed was to add a '&' to the start of the command:
    &hs.PluginFunction("MyPlugin", "", "MyFunction", {"Param A", "Param B", 0})
    This does not work. I receive the error: Running script, init error: Invalid character.
    How do I call hs.PluginFunction directly from HS Touch for HS3?
    I have same issue - works in a .vb script but not in a one line command in web interface
      Put the call in an event an call the event from HSTouch.
      -Rupp
        I'd log it as a bug but in the meantime you can put that command in a normal script and then call that script in HSTouch.
        My Plugins:
        Yeelight 3P | Nanoleaf 3P
          Did anybody log a bug on this?
          I am seeing this too, but not only from HST. I also see the issue from "direct script statements" in events.
          Calling the Plug-In function only seems to work when calling it from a 'proper' script or from another plug-in
          Nicolai L
            [QUOTE=NicolaiL;1139354]Did anybody log a bug on this?QUOTE]
            I found this bug: http://bugzilla.homeseer.com/bugzill...ug.cgi?id=1654
            Suggest you guys subscribe to this if you haven't already done so.
            Nicolai L
