Logitech Harmony Ultimate (Hub) Plugin
  • Originally posted by Rien du Pre View Post
    You can use manual polling in an event already.
    But how do you set up HS to recieve IR signals as a trigger ?
    Sorry, I didn't actually check if I could poll manually before I posted.
    In my case HS is running on Raspberry pi, so I could add an ir reciever to the GPIO inputs and use the GPIO addon in Homeseer. Don't you think?
    And if you're running HS on a windows machine I'm sure it wouldn't be very hard to get an ir reciever to interact with HS
    • Does this plugin work with the latest Harmony Hub
      Has anyone used this plugin and verified it works with the current Harmony Hub (the one that can be controlled also from Smartphones)?
      https://www.logitech.com/en-us/product/harmony-hub#section-product-hero
      • Originally posted by dzee View Post
        Looks like a normal hub to me, so I assume it will work.
        Rien du Pre
        The Netherlands
        Using:
        Homeseer PRO 3.0.0.435 on MacOS - Running a Mac Mini
        Plugin's:
        RFXCOM, Caddx, BLShutdown, BLLogMonitor, BLRadar, BLBackup, Log2Text, BLLAN, Z-Wave
        • Can't Download Harmony Hub from HS3 Store
          Just picked up a Harmony Hub and set it up. Every time I try to download the Harmony Hub plug-in from the HS3 plug-in manager Interfaces and Add-ins, it fails with "Error saving the downloaded file: error"
          I can download other plug-ins without a problem.
          Is there something wrong with the Harmony Hub plug-in on the store?
            I've tried it myself and it works in my test environment.
            Please contact Homeseer for further help
            Rien du Pre
            The Netherlands
            Using:
            Plugin's:
            • Thanks, Rien. I was able to download it on Sunday morning, so it was a temporary problem.
              Sent from my SAMSUNG-SM-N910A using Tapatalk
              • The plug-in can't connect to the hub any more, this is for a couple of days now. The ip of the hub hasn't changed (ststic lease) but i saw news artikel that Logitech triedres locale access on 21-dec after shutting it down on 18-dec. I did a sync with my phone and download software came by but it is not working.
                artikel: https://tweakers.net/nieuws/147196/h...-herstelt.html
                Homeseer error: H
                armony Hub Error Plugin: Harmony Hub Test Connectivity:Hub1: HARMONY COMMUNICATION LOGIN : FAILURE ERROR : connectToHarmony : Unable to connect to specified IP Address on specified Port -87
                the port number start from 30 to 90
                • Originally posted by The-Source View Post
                  https://forums.homeseer.com/forum/au...40#post1268640
                  Need to upragde hub firmware to 210
                  • Even with sync it still at 206 have to connect it to my laptop then i think
                      Did you actually read the post I linked? For lazy:
                      Here are Logitech’s instructions if you want to opt into the beta now:
                      Launch the MyHarmony software on your desktop computer.
                      From the login page, press the following keys to access the tool:
                      On Windows - Press Alt + F9
                      On Macs - Press Fn + Option + F9 or Option + F9.
                      Scroll down to the bottom where it says “FIRMWARE TO ENABLE XMPP. FOR DEVELOPERS ONLY.”
                      Be sure to read through the short warning and disclaimer to understand the impact of installing this firmware.
                      Click on Update Firmware.
                      Plug in your Harmony Hub via USB and click on Install.
                      • That seems to work 👍
                        • Same error did find any solution?
                          • Found solution on that link
