Script create device
  • Script create device
    Hi,
    How do Ic reate a device by a script and set device type and clear or set the unit code?
    Creation can be done by create deviceref if im correct.
    I am teying to accomplish this by use of vb.
    Regards
    Bart
    Regards Bart
    Win7 64Bit on Intel NUCI7 with SSD
    HSPRO 3.
    Devices; 1370 Events; 691
    Jon00 Scripts, JowHue, HSTouch, Plugwise, Z-wave, Ultranetatmo, Ultracam, PHlocation, BLUSBUIRT, MeiHarmony, Buienradar, MEiUnifi Pushover 3P, Random, Nest HSPhone and Blueiris
    Visonic Powermax Alarm System (HS3) Interface: http://www.domoticaforum.eu/viewtopic.php?f=68&t=11129
    Nobody,
    Im still trying to create a device via VBscript, which succeeds, but i also want to change location, devicecode, device type etc. tried this;
    Sub Main(params As Object)
    dim dv
    dv = hs.NewDeviceRef("Toon Test apparaat")
    If dv IsNot Nothing Then
    dv.Device_Type_String(hs) = "Joe Bazooka Bubble Gum"
    End If
    hs.WriteLog("apparaat referentie", dv)
    End Sub
    but this does not work...
    Regards Bart
    HSPRO 3.
      Originally posted by bartbakels View Post
      Nobody,
      dim dv
      End If
      End Sub
      Try this as a start
      Dim dv As Scheduler.Classes.DeviceClass = Nothing
      hs.WriteLog("apparaat referentie", dv.ref(hs))
      End If
      End Sub
      My Plugins:
      Yeelight 3P | Nanoleaf 3P
        Mrhappy,
        Thanks, Stupid me
        I got it all working in my script however I have 2 additional questions;
        now I create a device if needed and change values and devicestring by
        Dim Value
        Dim DevExists
        Dim Ref
        'Current temperature
        Value = currenttemp
        DevExists = hs.DeviceExistsCode("Toon-PV")
        If DevExists = -1 Then
           dv = hs.NewDeviceEx("Toon Temperatuur")
           dv.Location(hs) = "Toon"
           dv.Location2(hs) = "Status"
           dv.Code(hs) = "Toon-PV"
           dv.Device_Type_String(hs) = "Toon Thermostaat"
           dv.Image(hs) = "/images/toon/toon.png"
        End If
        Ref = hs.GetDeviceRef("Toon-PV")
        hs.SetDeviceValueByRef(Ref, Value , False)
        hs.SetDeviceString(Ref, Value & " Graden", True)
        However When i open the device settings of this devic,e the device code is getting cleared and the device will be recreated on the next script call. Did i forgot something?
        In addition how do i remove the little dimming lightbulb in front of the device?
        thanks in advance
        Bart
        Regards Bart
        HSPRO 3.
          hi,
          I already found my mistake, I needed to check on device address instead of code and instead of the code I now written the address.
          Regarding the devicevalues i used this which worked fine;
          GPair = New VGPair
          GPair.PairType = VSVGPairType.Range
          GPair.RangeStart = 0
          GPair.RangeEnd = 100
          GPair.Graphic = "/images/toon/TemperatureSP.png"
          hs.DeviceVGP_AddPair(ref, GPair)
          OR
          GPair = New VGPair
          GPair.PairType = VSVGPairType.SingleValue
          GPair.Set_Value = 0
          GPair.Graphic = "/images/toon/Idle.png"
          Regards
          Bart
          Regards Bart
          HSPRO 3.
            Hey guys - is there a way to not show the default light bulb images when creating a device via scripts? I know I can define images via VGPair but I don't want an image. Even though no VGPairs are defined it keeps showing default lightbulb on/off/dim images in the status field.
              Try setting the image property,
              Public Property Image(ByVal hs As IHSApplication) As String
              The Image property holds a path string to an image file to represent the device on the status views pages. The image path should be referenced from the root of the HTML folder under the main HomeSeer folder.
              My Plugins:
                thnaks for responding! I tried it and that sets the image itself for the device. However under STATUS it still defaults to show a lightbulb state next to the custom textual value settings.
                  bump for ideas
                    Try
                    hs.DeviceVGP_ClearAll(ref, True)
                    Wade
                    I know nothing...., nothing!!!
                      Originally posted by Sgt. Shultz View Post
                      Try
                      Good luck with that Wade, have only been complaining about that for last 2 years with counterargument about backward compatibility w/ HS2.
                      I set the device string to something like single blank or underscore to get rid of it.
                      Dirk
                        I am driving myself mad with this light bulb issue, I create four devices in a script with this routine;
                        Sub CreateDevices()
                            Dim CurrRef As Integer = 0
                            Dim BaseRef As Integer = 0
                            Dim root_dv As Scheduler.Classes.DeviceClass = Nothing
                            Try
                                Log("Devices Do Not Exist - Creating - Data Will Update On Next Run")
                                'four devices need to be created, root, current location, current time, am I at home
                                For i As Byte = 0 To 3 'needs to be four new devices
                                    Select Case i
                                        Case 0
                                            dv = hs.GetDeviceByRef(hs.NewDeviceRef(DAddS & " Root Device"))
                                            dv.Address(hs) = DAddS & "-Root"
                                            BaseRef = dv.Ref(hs)
                                        Case 1
                                            dv = hs.GetDeviceByRef(hs.NewDeviceRef(DAddS & " Current Location Data"))
                                            dv.Address(hs) = DAddS & "-CurrLoc"
                                        Case 2
                                            dv = hs.GetDeviceByRef(hs.NewDeviceRef(DAddS & " Current Location Time"))
                                            dv.Address(hs) = DAddS & "-CurrTime"
                                        Case 3
                                            dv = hs.GetDeviceByRef(hs.NewDeviceRef(DAddS & " Am I At Home"))
                                            dv.Address(hs) = DAddS & "-AmIAtHome"
                                    End Select
                                    dv.Location(hs) = "FollowMee"
                                    dv.Last_Change(hs) = Now
                                    dv.Device_Type_String(hs) = DAddS & " Device"
                                    Log("VGP Count: " & hs.DeviceVGP_Count(dv.Ref(hs)))
                                    hs.DeviceVGP_ClearAll(dv.Ref(hs), True)
                                    hs.DeviceVGP_Clear(dv.Ref(hs), 0)
                                    hs.DeviceVGP_Clear(dv.Ref(hs), 1)
                                    hs.saveeventsdevices()
                                    If i = 0 Then 'on the base device do this, set up the relationships between the devices
                                        root_dv = dv
                                        dv.Relationship(hs) = Enums.eRelationship.Parent_Root
                                    Else
                                        If root_dv IsNot Nothing Then root_dv.AssociatedDevice_Add(hs, dv.Ref(hs))
                                        dv.Relationship(hs) = Enums.eRelationship.Child
                                        dv.AssociatedDevice_Add(hs, BaseRef)
                                    End If
                                    'VSPairs? I think only the Am I At Home will need a VSPair
                                    Select Case i
                                        Case 0
                                            hs.setdevicestring(dv.Ref(hs), "Root Device", True)
                                        Case 1
                                            hs.setdevicestring(dv.Ref(hs), "Awaiting Data", True)
                                        Case 2
                                        Case 3
                                            Dim Pair As VSPair
                                            Pair = New VSPair(HomeSeerAPI.ePairStatusControl.Status)
                                            Pair.Value = 1
                                            Pair.Status = "I Am At Home"
                                            hs.DeviceVSP_AddPair(dv.Ref(hs), Pair)
                                            Pair.Value = 0
                                            Pair.Status = "I Am Not At Home"
                                    End Select
                                Next
                                Log("End Of Create Devices Routine")
                            Catch ex As Exception
                                Log("Create Devices Exception: " & ex.message.tostring)
                            End Try
                        End Sub
                        No matter what I do I cannot get rid of the light bulb icon, I have tried all sorts. Removing the VGPairs with _ClearAll and removing specific pairs by specifying a value, as a test I put in a count before and after removing and it always reports 0 so I am very confused, it seems not to have a VGPair to clear even though the graphics update suggesting that it has?
                        Dec-24 02:51:06 FollowMee End Of Create Devices Routine
                        Dec-24 02:51:06 FollowMee VGP Count: 0
                        Dec-24 02:51:06 FollowMee Devices Do Not Exist - Creating - Data Will Update On Next Run
                        Dec-24 02:51:06 FollowMee Am I At Home: True
                        As you can see on the image by default they all have the off light bulb indicator (why), then the last device when set to the value of one has the dim bulb indicator even though there are no VGPair's set up in the device property. On the bottom of the image you can see that 'Status' appears to be still in the realms of a normal virtual device with the value of one being dim. I have also tested whether any VSPair's exist that are not represented in the UI and it also returns a count of zero for these.
                        This appears to be something specific to creating them from scripts from what I can see, I have done it in plugins countless times and never had this issue.
                        It would be great if someone could put me out of my misery on this one...
                        My Plugins:
                          Hi Adam,
                          I believe the light bulbs are default if there are no status graphics added. Once you add specific status graphics, the light bulbs are gone. Manually created devices have the same issue.
                          Cheers
                          Al
                          HS 3.0.0.532: 1963 Devices 1141 Events
                          Z-Wave 3.0.1.261: 122 Nodes on one Z-Net
                            Adam,
                            Try setting dv.Interface(hs) to something other than blank i.e.
                            PHP Code:
                            dv.Interface(hs)="FollowMee"
                            Otherwise set the devicestring for the device which contains a blank image i.e.
                            PHP Code:
                            hs.SetDeviceString(dvRef"<img src=""/images/Homeseer/ui/5-x-5_trans_spacer.gif"">"True
                            Jon
                              Thanks guys, it was setting the interface property that sorted it, I am still a bit confused as to why when the help file says
                              Public Property Interface(ByVal hs As IHSApplication) As String
                              This property holds the name of the plug-in that owns/manages this device. If the property is null or an empty string, the device is not managed by a plug-in.
                              So if the device is not managed by a plugin (which in this case it isn't) I thought that you could leave the interface empty or pass nothing but it appears you can't without the bulb icons staying (everything else works fine) - is this a bug or just me not understanding it right? I know that setting the interface property has other implications like blocking the address and I think protecting the VSPair's from being edited which is not a bad thing but neither what I was expecting creating the device from a script.
                              My Plugins:
