DeviceScriptButton_Add Sample Script
  • DeviceScriptButton_Add Sample Script
    For those of you wanting to try the new hs.DeviceScriptButton_Add feature, I made this quick script to create a test device with 3 buttons. Main() creates the device and then the buttons are pressed, the ButtonPress Sub is called with a Parm. Hope it helps someone.
    Public Const ScriptName = "Add Button Test"
    Sub Main(parm as object)
    	Dim TestDeviceCodeName = "TestDevice001"
    	Dim a As Boolean
    	Dim ButtonInfo() As String
    	Dim DV As Object
    	Dim DT As New DeviceTypeInfo
    	Try
    		DV = hs.NewDeviceEx(TestDeviceCodeName)
    		DV.Location(hs) = "Test"
    		DV.Location2(hs) = "Test"
    		DV.Code(hs) = TestDeviceCodeName
    		dv.DeviceType_Set(hs) = DT
    		hs.SaveEventsDevices
    		DT = Nothing
    		DV.Status_Support(hs) = True
    		DV.Can_Dim(hs) = False
    		DV.MISC_Set(hs, Enums.dvMISC.SHOW_VALUES) 'This is &H100
    		DV.MISC_Clear(hs, Enums.dvMISC.STATUS_ONLY) 'This is &H10
    		DV = Nothing
    		hs.WriteLog(ScriptName, "Test Device " & TestDeviceCodeName & " created")
    	Catch ex As Exception
    		hs.WriteLog(ScriptName, "Error C: " & ex.Message)
    	End Try
    	Dim DevExists As Integer
    	DevExists = hs.DeviceExistsCode(TestDeviceCodeName)
    	a = hs.DeviceScriptButton_Add(DevExists, "Button 1", "test_device_creation.vb", "ButtonPress", "Button1", 1, 1, 1)
    	If a  Then
    		hs.writelog(ScriptName,"Device Script for Button 1 Successfully Added")
    	Else
    		hs.writelog(ScriptName,"Error: Device Script for Button 1 NOT Added")
    	End If
    	a = hs.DeviceScriptButton_Add(DevExists, "Button 2", "test_device_creation.vb", "ButtonPress", "Button2", 1, 1, 1)
    	If a  Then
    		hs.writelog(ScriptName,"Device Script for Button 2 Successfully Added")
    	Else
    		hs.writelog(ScriptName,"Error: Device Script for Button 2 NOT Added")
    	End If
    	a = hs.DeviceScriptButton_Add(DevExists, "Button 3", "test_device_creation.vb", "ButtonPress", "Button3", 1, 1, 1)
    	If a  Then
    		hs.writelog(ScriptName,"Device Script for Button 3 Successfully Added")
    	Else
    		hs.writelog(ScriptName,"Error: Device Script for Button 3 NOT Added")
    	End If
    	ButtonInfo = hs.DeviceScriptButton_List(DevExists)
    	hs.Writelog(ScriptName,"Button 1 created with following info " & ButtonInfo(0))
    	hs.Writelog(ScriptName,"Button 2 created with following info " & ButtonInfo(1))
    	hs.Writelog(ScriptName,"Button 3 created with following info " & ButtonInfo(2))
    End Sub
    Sub ButtonPress(Input As Object)
    	Dim DevID As Integer = Input(0) 						'Integer - The device reference ID.
    	Dim ScriptCallParm As String = Input(1)					'String - Script Parm Passed from Button
    	If ScriptCallParm = "Button1" Then
    		hs.Writelog(ScriptName,"Button 1 has been pressed!")
    	End If
    	If ScriptCallParm = "Button2" Then
    		hs.Writelog(ScriptName,"Button 2 has been pressed!")
    	End If
    	If ScriptCallParm = "Button3" Then
    		hs.Writelog(ScriptName,"Button 3 has been pressed!")
    	End If
    End Sub
    Madmax,
    Thanks, this helped me getting it work in my scripts.
    However i think we have a bug in hstouch. When we select one of the buttons in hstouch with the device browser, its always triggers the same parameter, in your case button 3 pressed. Do you also have this issue?
    Tonight im trying to create also identical valuepairs, maybe this solves this issue.
    regards
    bart
    Regards Bart
    Win7 64Bit on Intel NUCI7 with SSD
    HSPRO 3.
    Devices; 1370 Events; 691
    Jon00 Scripts, JowHue, HSTouch, Plugwise, Z-wave, Ultranetatmo, Ultracam, PHlocation, BLUSBUIRT, MeiHarmony, Buienradar, MEiUnifi Pushover 3P, Random, Nest HSPhone and Blueiris
    Visonic Powermax Alarm System (HS3) Interface: http://www.domoticaforum.eu/viewtopic.php?f=68&t=11129
      Hi, I haven't tried this with HSTouch yet.
        Guys,
        Rick has corrected the issue with DeviceScriptButton_Add not working in HSTouch which will be available in the next version of HS3.
        The bad news is that there will be a new parameter added to the command so you need to update your code. This new parameter is a unique value which is not used in another button or value/status pair for that device.
        Jon
          Hi jon00
          Great news. So I can update my scripts. I guess thedevices need to be removed and recreated by the script? In addition the documentation will be updated as well?
          So jon u need also to update the hue plugin i guess? Thnx again for the great support
          Regards
          Bart
          Regards Bart
          HSPRO 3.
            Can anyone get the DeviceScriptButton_Add function to work with the new value parm? I'm having trouble
            This doesn't work:
            a = hs.DeviceScriptButton_Add(DevExists,"Button 1",204000,"test_device_creation.vb","ButtonPress","Button1", 1,1,1)
            I just added a random 204000 value for the sample button
            http://homeseer.com/support/homeseer...button_add.htm
              You need to use hs.DeviceScriptButton_AddButton NOT hs.DeviceScriptButton_Add
              Jon
                Thanks jon00
                This now works with newer versions of HS:
                	Dim a As Boolean
                	Dim DV As Object
                	Try
                		DT = Nothing
                		DV = Nothing
                	End Try
                	a = hs.DeviceScriptButton_AddButton(DevExists, "Button 1", 204000, "test_device_creation.vb", "ButtonPress", "Button1", 1, 1, 1)
                	If a  Then
                	Else
                	End If
                	a = hs.DeviceScriptButton_AddButton(DevExists, "Button 2",204001, "test_device_creation.vb", "ButtonPress", "Button2", 1, 1, 1)
                	If a  Then
                	Else
                	End If
                	a = hs.DeviceScriptButton_AddButton(DevExists, "Button 3",204002, "test_device_creation.vb", "ButtonPress", "Button3", 1, 1, 1)
                	If a  Then
                	Else
                	End If
                End Sub
                	End If
                	End If
                	End If
                End Sub
                  I tried this unchanged and got the below logs. My goal is to create a virtual device with a drop list to select from 1-10, and "+1" and "-1" buttons to increment or decrement the current value. I did already create the virtual device with drop list manually, but need the script buttons to increment & decrement the value.
                  I need to be able to use the AddDeviceActionToEvent function from another script to add an action to an event to increment the value of this virtual device. I originally had a regular counter device holding this value, but found there apparently is no CAPIControl to increment the counter. It looks like this DeviceScriptButton_AddButton function does add CAPIControls which I could then reference in the AddDeviceActionToEvent function. Any help is greatly appreciated.
                  Jul-03 7:27:30 PM Error 1 Running script /usr/local/HomeSeer/scripts/AddButtonTest.vb :Exception has been thrown by the target of an invocation.Object reference not set to an instance of an object
                  Jul-03 7:27:30 PM Add Button Test Error: Device Script for Button 3 NOT Added
                  Jul-03 7:27:30 PM Add Button Test Error: Device Script for Button 2 NOT Added
                  Jul-03 7:27:30 PM Add Button Test Error: Device Script for Button 1 NOT Added
                  Jul-03 7:27:30 PM Add Button Test Error C: Cannot find the requested class member.
                  Jul-03 7:27:23 PM Event Running script in background: /usr/local/HomeSeer/scripts/AddButtonTest.vb
                  Jul-03 7:27:23 PM Event Event Trigger "Tests VirtualDev with scriptButtons"
                  Jul-03 7:27:23 PM Event Event Tests VirtualDev with scriptButtons triggered by the event page 'Run' button.
                  John
                  Current Date/Time: 7/3/2016 7:45:31 PM
                  HomeSeer Version: HS3 ZEE S2 Edition 3.0.0.291
                  Linux version: Linux HomeTrollerZeeS2 3.18.11-v7+ #781 SMP PREEMPT Tue Apr 21 18:07:59 BST 2015 armv7l GNU/Linux System Uptime: 9 Days 2 Hours 58 Minutes 43 Seconds
                  IP Address: 192.168.0.32
                  Number of Devices: 221
                  Number of Events: 195
                  Available Threads: 399
                  Enabled Plug-Ins
                  3.0.0.27: EasyTrigger
                  3.0.0.68: HSTouch Server
                  3.0.5959.34353: UltraM1G3
                  3.0.0.50: weatherXML
                  3.0.1.83: Z-Wave
                    I just tried the script here and works fine on a Windows version of Homeseer. Sorry but I cannot test on Linux.
                    Remove or remark the following lines and see if the error persists:
                    DT = Nothing
                    Also change this:
                    To
                    DV.MISC_Set(hs, &H100) 'This is &H100
                    Jon
                      Same log errors after those changes. I just loaded VS Express, so I'll start playing with (no experience with it yet) that to try to understand better where the problems might be. Thanks.
                      John
