Going through Events
  • Going through Events
    HS2 had the quite useful EventEnumerator.
    How can we loop through events in HS3?
    You can see the fun here http://forums.homeseer.com/showthread.php?t=165610 but reading the scripting docs I wonder if you can get a list of events using Event_Info_All and then examine the structure to get the names of the events...depends what you are trying to do with them though as to whether that helps.
    My Plugins:
    Yeelight 3P | Nanoleaf 3P
      Thanks!
      That way you can at least get the reference and Name.
      Now I wonder if Linq is supported or not in HS3. I believe it was, but I can't get it to work now...
        Originally posted by Moskus View Post
        Thanks!
        Hi Moskus, did you ever get this working? I was looking to create a script to enumerate all the events and loop through them. Do you have something you can share?
        Al
        HS 3.0.0.532: 1963 Devices 1141 Events
        Z-Wave 3.0.1.261: 122 Nodes on one Z-Net
          Al
          Sure!
          But sadly, Linq isn't as supported as we could have hoped. It seems that the compiler isn't 100% there for some reason.
          I hope you use tenScripting, there you can test this directly.
              Public Function Events() As System.Collections.Generic.List(Of HomeSeerAPI.strEventData)
                  Dim _events As New System.Collections.Generic.List(Of HomeSeerAPI.strEventData)
                  For Each e As HomeSeerAPI.strEventData In hs.Event_Info_All
                      _events.Add(e)
                  Next
                  Return _events
              End Function
              Public Sub Test()
                  Dim myEvents = From e In Events()
                                 Where e.Flag_Enabled AndAlso e.Flag_Do_Not_Log
              End Sub
          If you run the sub Test(), the myEvents variable will be a list (of type HomeSeerAPI.strEventData) of all events that are enabled and are set to not write to the log when triggered.
          The Events() function is just a quick Linq wrapper I wrote. It just gathers information from hs.Event_Info_All, and you can use that directly if you prefer.
          Alot of fun!
            Sure!
                        _events.Add(e)
                    Next
                    Return _events
                End Function
                Public Sub Test()
                End Sub
            Alot of fun!
            Great, thanks, will give it a try!
            Cheers
            Al
