HS3 Perl scripts
  • HS3 Perl scripts
    I try to verify if my HS2 perl scripts are compliant in HS3 in the windows and linux versions.
    My conclusions are the following :
    On windowsOn Linux
    You have the same behaviour than on windows but, the script does not run. You receive the following message : "Cannot run .txt script on Linux, only .vb scripts are supported". I don't know if I have to do something special for HS3 because Perl is installed correctly and standalone scripts works fine.
    Perl experience in new homeseer version is welcome !
    Are you still using perl?
    I am just now trying to transistion to HS3 (on Windows) and have many HS2 perl scripts.
    However, I can't even get a script as simple as the following to run
    sub main()
        $hs->WriteLog("Error", "This is a test");
    I get this error, even with just a blank main sub:
    Running script: Index was out of range. Must be  non-negative and less than the size of the collection. Parameter name: startIndex->   at System.String.IndexOf(String value,  Int32 startIndex, Int32 count, StringComparison comparisonType)    at System.String.IndexOf(String value, Int32 startIndex)    at  A.c1b0f37609f28fb7afed8d440680e6db4.ce86a0a55d3661fa218b566b5ba926ee0(String  ceefe476d1f77adc790c7782141798e1f, Boolean  ce791fe9d8290e0d18cd0af1e42db139a, Int32  c3fda549ce0b74c9ad9fc210b529b2226, String  c0cf6c15fc505ce256a93afdc5f2268a9, Boolean  cc5b1dd80b9769b83d5de72520f2500e0, String  c18f60d71139b909e1bc745dcca77e3f9, String  cc463bfced87bf099c3125a86fe30843e, Int32  c135c28f517be83dec993779636acd860, String  cdba5e903fed69597b9572ece7ed2b748, Object  c70fb72fe0bbd8641a8134e71b176a648, Int32  caafe238b1576633e332c6c566f5707f4)
    Any thoughts or help would be greatly appreciated.
