How to allow DeviceScriptButton to execute at the same time?
  • How to allow DeviceScriptButton to execute at the same time?
    It seems as a default any DeviceScriptButton added to a device is set to "Single Instance Option" by default. Is there a way to set this so it can run at the same time?
    The error I get:
    "Not running script since its already running: AV-Denon-HTTP.vb Single instance option enabled in event properties"
    What I am doing: I have a set of devices I use to send HTTP commands to my denon. They all use the same script's "SendCommand" function. so when I run the following Event one of them invariably fails as it is executing the same script at the same time.
    Set Device Media Family Denon - Power to ON
    Then Set Device Media Family Denon - Input to DIRECTV
    Then Set Device Media Family Denon - Surround to STANDARD
    Then Set Device Media Family Denon - Volume to Volume 35%
    Bump - any ideas? Is this a bug I should log?
      Use the new hs.DeviceScriptButton_AddButton function. This is set to multi-instance script running by default.
      Example: http://board.homeseer.com/showpost.p...72&postcount=8
      Jon
        Works! Thx!!
          Hi, robilium
          I have also a denon (AVR3313),
          i want send some command to denon to switch on my bluray, close the shutter, and other action.
          can you share your script?
          Jean-francois.
            Originally posted by jfla View Post
            Hi, robilium
            Jean-francois.
            Same question
            Peter
            http://ohh.pcgsm.nl
