Contacting HomeSeer This Week
See more
See less
JowiHue Philips Hue control beta now available
  • #46
    I have still been having the issue with the sqllite dll. Even if I disable all of my plugins and move the sqllite dll from the root directory hs3 still throws an error. I am running the latest beta 107 and thinking it might be related to hsphone.
    HSPRO,HS3PRO, BLsecurity, , MCSxap, HSTouch Android, UltraGCIR, CM15a, USBUIRT, BLUSBUIRT, WIFIRGB, BLAB8SS, BLcontrol, BLGData, BLLAN,BLOccupied, BLRadar, BLVolume, iTunesDAAP, UltraGCIR3, Airplayspeak, BLalarm, BLbackup, BLLED, BLrandom, BLReminders, BLRF, BL Speech, Hyperion, IFTTT, KINECT, XBMC, MCSprinkers PRO, PHLocation, ULtrapioneer, Ultralog, ultraweatherbug, Z,troller, GC-100, GC WIFICC, GC-WIFI SERIAL, Nitrogen logic depth camera controllers,
    • #47
      I sure hope HST would not do this as I am only following the guidelines as Rick state in another thread. I am not using HS3 latest beta yet as I have no need of HSPhone myself.
      I will try a test upgrade later this week to see I am getting the same. But if the beta HS3 is depending on this we have a challenge.
      If your removing the dll from the root, are you getting the same error, even without JowiHue running?
      Wim
      -- Wim
      • #48
        If I remove the dll. Hs throws a ton of errors and doesn't load the data base. I have played around with this and cant even get hs to run successfully without any plugins really wondering if it is hsphone or the zwave beta but not sure
        • #49
          Is there anyway to have your plug in uae a different data base
          • #50
            I would put in a bugzilla if only HS3 is running (no other plugins) and throwing an error if the sqllite is not in the root directory. Older versions of HS3 have their sqllite interop dll in the bin directory. If HS3 is moving this, there will be more plugins in trouble.
            I will test with the new HS3 beta version later this week to confirm if it is HS3 itself causing this.
            Wim
            -- Wim
            • #51
              Kenrad,
              I am running also HS3 1.07 with hsphone enabled and no issues with the sqllite nor with the JowiHue plugin. I even use BDgraphs, which for my understanding uses the same dll.
              regards
              bart
              Regards Bart
              Win7 64Bit on Intel NUCI7 with SSD
              HSPRO 3.
              Devices; 1370 Events; 691
              Jon00 Scripts, JowHue, HSTouch, Plugwise, Z-wave, Ultranetatmo, Ultracam, PHlocation, BLUSBUIRT, MeiHarmony, Buienradar, MEiUnifi Pushover 3P, Random, Nest HSPhone and Blueiris
              Visonic Powermax Alarm System (HS3) Interface: http://www.domoticaforum.eu/viewtopic.php?f=68&t=11129
              • #52
                Excited to try it. . . .but
                Found your plugin and was excited to try it out, but I get the following message in the plug-in status area.
                **FATAL**: Failed getting InterfaceStatus from JowiHue - the interface was not found in the list of active interfaces.
                I also get this on a few other third party apps.
                Any insite?
                Appreciate the time.
                • #53
                  Any insite?
                  I see this error every now and then also, even on HST plugins. HSTouch is quite popular in that area Easiest way to solve it is to disable and enable the plugin showing the issue. I think it is an issue with HST while initialising plugins.
                  Happy testing!
                  Wim
                  PS. Soon I will release the release candidate of this plugin
                  -- Wim
                  • #54
                    Wim,
                    Just to let you know. Until now running great and stable for 4 weeks...
                    Bart
                    Regards Bart
                    HSPRO 3.
                    • #55
                      Originally posted by bartbakels View Post
                      Wim,
                      Bart
                      Bart,
                      Great news! Was hoping this was the case as I do not get many issues so far reported. You might like the new version. Lots of small enhancements comming. Scripting enabled, scene interface more user friendly, color conversion and more stabilty. I am pretty excited on the quality of the new version here.
                      One test needed still with a bloom version. Ordered it today and hope it will pass my final tests.
                      If all goes well, the release candidate will be available this weekend.
                      Wim
                      -- Wim
                      • #56
                        By bloom died on me few weeks ago.. I have 7 hues 2 livingcolors( new and old gen) and a livingwhite
                        Bart
                        Regards Bart
                        HSPRO 3.
                        • #57
                          Wanted to let you know that here the plugin also works without a glitch!
                          Verstuurd vanaf mijn Nexus 5 met Tapatalk
                          • #58
                            Bart
                            Bart,
                            Glad you are having livingwhite. One of the changes in the plugin is that the device images of the root device should be reflecting the actual light. Also (for livingwhite an the new lux) it will no longer show the color devices when it is not necessary. There will be a conversion when you would start the release candidate for the firsttime adjusting all devices. As I do not have a living white, I hope you can do the checking later
                            Hard part is finding the modelnumbers when you do not have them.
                            And same models seem to have different modelnumbers..
                            To confirm I have your lights ready in the plugin, could you give me your set of modelnumbers? I suspect I do not yet have the old gen living color and am unsure of the living white?
                            You can find the modelnumber on the root device properties in the JowiHue tab.
                            Thanks in advance!
                            Wim
                            -- Wim
                            • #59
                              Wim,
                              I will look into this. I still also have this information, from the selfmade control scripts i used before, which I posted on the Dutch forum.
                              come back to you
                              regards
                              bart
                              Regards Bart
                              HSPRO 3.
                              • #60
                                Win,
                                my model no`s are;
                                Hues: LCT001
                                Living color old gen: LLC006
                                Living color New gen: LLC006
                                Living White: LWB001
                                so the living colors seem to have the same no.
                                By the way, there are also the iris , bloom, ledstrips, new GU10, en the TAP Switch. Exact model nos can prob ably found at everyhue.com
                                and at http://www2.meethue.com/en-us/the-range/hue-lights/
                                regards
                                bart
                                Regards Bart
                                HSPRO 3.
