Trying to Enable Controls using propertySet.Add
  • Trying to Enable Controls using propertySet.Add
    I am trying to enable a jquery button from the postBackProc using propertySet.Add. Here is the control:
    clsJQuery.jqButton jqbut = new clsJQuery.jqButton("btnenrollstat",  "Enroll Thermostat", this.PageName, false);
    jqbut.toolTip = "Enroll Thermostat and Create Thermostat Devices";
    jqbut.enabled = false;
    I have tried both of these calls in the postBackProc but neither have any effect:
    if (isInputComplete()) this.propertySet.Add("btnenrollstat", "removeattr=disabled");
    if (isInputComplete()) this.propertySet.Add("btnenrollstat", "addattr=enabled");
    Any help would be appreciated.
    Kirby
    i got the following from HST:
    Me.propertySet.Add("SETRESET_gLongitude" & clsJQuery.ID_IDENT, "removeattr=disabled")
    Note that you may have to add the “ID_IDENT” as we add that identifier to all control ID’s.
    hope this helps
    Mark
    HS3 Pro 3.0.0.435
      Thanks, Mark. This did help. The IDs in the html and the call now match. Here's the HTML:
      <button type='submit'   id='btnEnrollStat_ID598385'  name='btnEnrollStat'  title
      ='Enroll Thermostat and Create Thermostat Devices'  disabled='disabled' >Enroll
      Thermostat</button>
      What threw me was this note in the documentation:
      Note that ID_IDENT is only appended if an ID is not explicitly set when a jquery control is created. If you DO specify an ID it is not appended.
      I also noticed that there is a disabled attribute in the html so it should work. I didn't though see any change in the page. Is there anything that needs to be done to get the page to update?
        i believe the .ID_IDENT is used in case there are multiple instances of a plugin running. this occurs in triggers and actions as well. assume HS appends something to your IDs. I usually check the source html generated in the browser to see what is actually created.
        Mark
        HS3 Pro 3.0.0.435
          Thermostat</button>
          Did you ever get this to work? I have the same problem, everything is correct but the page does not change.
            This worked for me:
            This is in postBackProc:
            if (isInputComplete()) this.propertySet.Add("btnEnrollStat" + clsJQuery.ID_IDENT, "removeattr=disabled");
            btrn EnrollStat is defined as:
            clsJQuery.jqButton jqbut = new clsJQuery.jqButton("btnEnrollStat", "Enroll Thermostat", this.PageName, false);
                        jqbut.enabled = enabled;
                        jqbut.functionToCallOnClick = "$.blockUI({ message: '<h2><img src=\"/images/" + hspi.IFACE_NAME + "/spinner.gif\" /> Creating Thermostat Devices...</h2>' });";
                        stb.Append(jqbut.Build() + "<br><br>");
              This worked for me:
              so simply adding
              this.propertySet.Add("btnEnrollStat" + clsJQuery.ID_IDENT, "addattr=disabled");
              should disable the button?
              not working for me.
