How to access Address Book
  • How to access Address Book
    looking for a way (scripting) to access the contact class to check a phone # ?
    I can't seem to find the examples...
    Don
    Hi Don,
    I have some scripts that I can post tonight. I use it to retrieve names associated with a phone number. What are you trying to do?
    Cheers
    Al
    HS 3.0.0.532: 1963 Devices 1141 Events
    Z-Wave 3.0.1.261: 122 Nodes on one Z-Net
      I have a PBX that generates a number w/ an incoming call. Rich never fixed HSPhone's setting problems, so I'm using this to write to and pull data from the contact list.
      Would love to see your code....
      Don
        Hi Don,
        Here's a code snippet from a script that creates a log of the last 10 callers. It finds a phone number (defined as the variable Phone)in the callers log and then looks in the HSPhone address list to find a match and then sets a variable called Caller with the name.
        adr_count = hsp.ADRCount
        For i = 1 To adr_count
        	Set contact = hsp.ADRGet(i)
        	If Phone = Trim(contact.home_phone) or Phone = Trim(contact.home_phone_2) or Phone = Trim(contact.cell_phone) or Phone = Trim(contact.cell_phone_2) or Phone = Trim(contact.business_phone) or Phone = Trim(contact.business_phone_2) Then
        		If contact.first <> "" Then
        			Caller = contact.first & " " & contact.last
        		ElseIf contact.company_name <> ""  Then
        			Caller = contact.company_name
        		Else
        			Caller = Phone
        		End If
        	End If
        Next
        Note that this is from a vbscript script and may need a bit of modification to work in vb.
        Hope that helps. Let me know if you have any questions.
        Cheers
        Al
          Thanks. That helps.
          Don
