jqDatePicker fails to put control id in postback data
  • jqDatePicker fails to put control id in postback data
    Following the example implementations in the SDK, my PostBackProc is expecting to decide what happened on the page based on the posted string data, which is split up into a name/value collection, using the "id" item.
    So far I've had no trouble with this, but I just tried to use my first jqDatePicker, and the posted string has only the data in it, and even then it's in the wrong format. The other controls send back something like:
    "{id=oMyControl;MyControl=12345}"
    but jqDatePicker is coming back with:
    "{oMyControl=12345}"
    I can code around this, but it's sloppy... has anyone else used this control and figured out a way to make it behave correctly?
    I'm seeing similar behavior with the jqMultiSelect control... am I missing something?
