'Trigger' is a type and cannot be used as an expression
  • 'Trigger' is a type and cannot be used as an expression
    Hi All,
    I have a paging system I run on my HS setup which allows me to respond to calls and have the house turn on lights and so on. Initially I was running this through a serial port, however I came to the realization that I am using the data across a number of different applications (Homeseer, Web Server, Push Messaging and so on). With this in mind I have started the task of converting my program to work on websockets, so that I have one central 'processor' which handles all of the pager messages and extracts dates, addresses, geocodes and so on, and this is passed through a websocket connection to the listening clients (e.g. Homeseer).
    I have almost converted my program, but I am noticing on this code below, I am getting two Errors. This has be confused because I thought I had copied and pasted the cost so I am not sure what these errors mean, or how to fix them.
    The errors are
    1. 'trigger' is a type and cannot be used as an expression (relates to DeserialiseObject)
    2. reference to a non shared member requries an object reference (relates to trigger.keys)
    I am at a bit of a loss with this as I programmed the code so long ago I have no idea how I should be changing the error 1 (which i think should fix error 2), can anyone point me in the right direction as to what I have done wrong and how to fix it?
    Many Thanks!
    Public Sub CheckTriggers(ByVal cPriority As String, ByVal cBrigade As String, ByVal cCallType As String, ByVal cCapcode As Integer, ByVal cMessage As String)
            Try
                Dim TrigsToCheck() As IAllRemoteAPI.strTrigActInfo = Nothing
                Dim TC As IAllRemoteAPI.strTrigActInfo = Nothing
                Dim sKey As String
                Dim Priority As String = ""
                Dim Brigade As String = ""
                Dim CallType As String = ""
                Dim UID As String
                Try
                    TrigsToCheck = callback.TriggerMatches(IFACE_NAME, 1, -1)
                Catch ex As Exception
                End Try
                If TrigsToCheck IsNot Nothing AndAlso TrigsToCheck.Count > 0 Then
                    For Each TC In TrigsToCheck
                        UID = TC.UID.ToString
                        If Not (TC.DataIn Is Nothing) Then
                            DeSerializeObject(TC.DataIn, trigger)
                        End If
                        For Each sKey In trigger.Keys
                            Select Case True
                                Case InStr(sKey, "Priority_" & UID) > 0
                                    Priority = Trim(trigger(sKey))
                                Case InStr(sKey, "Brigade_" & UID) > 0
                                    Brigade = Trim(trigger(sKey))
                                Case InStr(sKey, "CallType_" & UID) > 0
                                    CallType = Trim(trigger(sKey))
                            End Select
                        Next
                        If (Priority = cPriority Or Priority = "Any") And (Brigade = cBrigade Or Brigade = "Any") And (CallType = cCallType Or CallType = "Any") Then
                            Console.WriteLine(" the message that triggered this was " & cMessage)
                            callback.TriggerFire(IFACE_NAME, TC)
                        End If
                    Next
                End If
                Console.WriteLine("##ERROR## " & ex.Message)
                Console.WriteLine("")
            End Try
        End Sub
    HS3 PRO, Win10, WeatherXML, HSTouch, Pushover, UltraGCIR, Heaps of Jon00 Plugins, Just sold and about to move so very slim system.
    Facebook | Twitter | Flickr | Google+ | Website | YouTube
    Have you got the trigger object declared for it to be deserialised into?
    You can also test the deserialise
    For Each TrigValue As String In trigger.Values
    Log("trigger.Values: " & TrigValue, LogLevel.Debug)
    Next
    My Plugins:
    Yeelight 3P | Nanoleaf 3P
      Thanks for the tips, turns out by accident I had removed Dim trigger as new trigger
