Action with text input issue
  • Action with text input issue
    Hi all,
    I'm trying to create an action in my plugin with text input boxes. See attachment
    I'm using the following code:
       Public Function ActionBuildUI(ByVal sUnique As String, ByVal ActInfo As IPlugInAPI.strTrigActInfo) As String Implements HomeSeerAPI.IPlugInAPI.ActionBuildUI
            Dim stb As New StringBuilder
            If ValidAct(ActInfo.TANumber) Then
                Log("Plugin: " & IFACE_NAME & " Action number is: " & ActInfo.TANumber, LogType.LOG_TYPE_INFO)
                If ActInfo.TANumber = 1 Then
                    If Not (ActInfo.DataIn Is Nothing) Then
                        DeSerializeObject(ActInfo.DataIn, action)
                    Else 'new event, so clean out the action object
                        action = New action
                    End If
                    Dim Keypad As New clsJQuery.jqTextBox("Keypad" & sUnique, "text", "192", "", 5, True)
                    Dim MessageText As New clsJQuery.jqTextBox("MessageText" & sUnique, "text", "Your message", "", 32, True)
                    stb.Append("Enter Keypad Address:" & Keypad.Build & "<br>")
                    stb.Append("Enter Keypad Message:" & MessageText.Build)
                End If
            Else
                Return "Error, Action number for plug-in " & IFACE_NAME & " was not set."
            End If
            Return stb.ToString
        End Function
    The problem is that it will not save the values.
    How can I solve this ?
    Thanks.
    Rien du Pre
    The Netherlands
    Using:
    Homeseer PRO 3.0.0.500 and latest HS4 BETA on MacOS - Running a Mac Mini
    Plugin's:
    RFXCOM, Caddx, BLShutdown, BLLogMonitor, BLRadar, BLBackup, Log2Text, BLLAN, Z-Wave
    Anyone ???
    Rien du Pre
    The Netherlands
    Using:
    Plugin's:
      What do you mean by not save the issues, do you mean the auto post back or that the event will not collapse?
      My Plugins:
      Yeelight 3P | Nanoleaf 3P
        Normally when you fill in the required fields or options, it says what the action is. Now the input field stay 'open'
        Rien du Pre
        The Netherlands
        Using:
        Plugin's:
          Sorry but I am not quite sure I follow, if when you press the yellow arrow to collapse the event then it is not collapsing that would point to the ActionProcessPostUI having issues to me. I would be debugging that function to ensure that all of the elements are being added, you also need to consider ActionConfigured is returning the correct value.
          My Plugins:
            I'm still haven't got this working. Can anyone shed some light at this please ??
            Many thanks in advance.
            Rien du Pre
            The Netherlands
            Using:
            Plugin's:
              I think it is the same problem travisdh was having the other day, where you are deserialising the data you are not actually doing anything with it and you need to be putting that data into the default text properties of the text box, at the minute you are leaving it always blank.
              My Plugins:
                This is the thread that may help you http://forums.homeseer.com/showthrea...25#post1170025 - if you look in ActionBuildUI you will see the loop starting 'For Each sKey In action.Keys', you will need this in your example to get the data out of the Action object if it exists and to use it for the default text.
                My Plugins:
                  Thanks mrhappy.
                  Problem solved, based on the thread you pointed me to.
                  Many thanks again :-)
                  Rien du Pre
                  The Netherlands
                  Using:
                  Plugin's:
