Exception deserializing message: Object reference not set to an instance of an object
  • Exception deserializing message: Object reference not set to an instance of an object
    Just wondering if anyone has some tips on how to debug this error, I have narrowed it down to a trigger issue, and although the UI gets built, when I select the fields from dropdown lists, they get passed to the TriggerConfigured sub which appears to be where the error is occuring.
    The sub does not look wrong to me though, which is where I am very confused at why the error is occuring. How can I go about seeing what the deserializing error actually is, or what it is trying to write to, and receive from the database to work out how to actually fix this error.
    Narrowing it down a bit has helped, but I am just now not too sure how to identify what is causing the error in the sub itself.
    To clarify my approach, I have been adding console.writeline components in the various parts of the plugin to see which subs are being called, after I select the text from the dropdown box in HS3 event it does call the below trigger which should be checking for the Priority_ and Brigade_ which are also spelt the same in the BuildUI part.
    What is the practice for determining what is actually going wrong as I am starting to lose my mind slightly working out how to fix this. What is more frustrating is that it was working when I had 3 fields, and I determined one field was no longer needed so I removed it, deleted all of the associated events and removed all references to it, but it still does not work
    Public ReadOnly Property TriggerConfigured(ByVal TrigInfo As HomeSeerAPI.IPlugInAPI.strTrigActInfo) As Boolean
            Get
                Try
                Dim Configured As Boolean = False
                Dim sKey As String
                Dim UID As String
                UID = TrigInfo.UID.ToString
                If TrigInfo.TANumber = 1 Then
                    Dim itemsConfigured As Integer = 0
                    Dim itemsToConfigure As Integer = 2
                    If Not (TrigInfo.DataIn Is Nothing) Then
                        DeSerializeObject(TrigInfo.DataIn, trigger)
                        For Each sKey In trigger.Keys
                            Select Case True
                                Case InStr(sKey, "Priority_" & UID) > 0 AndAlso trigger(sKey) <> ""
                                    itemsConfigured += 1
                                Case InStr(sKey, "Brigade_" & UID) > 0 AndAlso trigger(sKey) <> ""
                            End Select
                        Next
                        If itemsConfigured = itemsToConfigure Then Configured = True
                    End If
                    Return Configured
                ElseIf TrigInfo.TANumber = 2 Then
                    Dim itemsToConfigure As Integer = 1
                            Select Case True
                                Case InStr(sKey, "Regex_" & UID) > 0 AndAlso trigger(sKey) <> ""
                            End Select
                        Next
                    End If
                    Return Configured
                Else
                    Return "Error"
                End If
                Catch ex As Exception
                    Console.WriteLine("TC Err:" & ex.Message)
                End Try
            End Get
        End Property
    HS3 PRO, Win10, WeatherXML, HSTouch, Pushover, UltraGCIR, Heaps of Jon00 Plugins, Just sold and about to move so very slim system.
    Facebook | Twitter | Flickr | Google+ | Website | YouTube
