Error Updating plug-in
  • Error Updating plug-in
    I am trying to update a plugin that I have written through the updater. When the updater tries to install the plugin, I get the following error:
    HS3\HSPI_OMNISTAT_3.exe, detailed error: The process cannot access
    the file 'C:\Program Files\HomeSeer HS3\HSPI_OMNISTAT_3.exe' because it
    is being used by another process.
    Disabling the plug-in first doesn't help. If I rename the original exe, it will install fine. I also noticed that the "Uninstall" button doesn't do anything.
    Have I left something out of my plugin?
    do you have the 'overwrite' option set in your install.txt file? its the ",0" at the end
    this is the first line of my install.txt file
    HSPI_Insteon.exe,.,0
    The updater and its process is controlled by HS3.
    I would suggest contacting Rich directly about this issue
    Mark
    HS3 Pro 3.0.0.435
      Mark,
      Is that an O as in overwrite or is it a 0 zero? I have a zero at the end.
        Originally posted by Kirby View Post
        Mark,
        A zero
        Mark
        HS3 Pro 3.0.0.435
