HSTouch friendly plugins
  • HSTouch friendly plugins
    Are there any directions or guidance to making a plugin HSTouch friendly. I cant seem to make a button toggle my device. I have values of 0 for off and 1 for on with a bunch of other values that represent other things, however I cant get toggle device or display status to work in HSTouch.
    If it ain't broke, don't fix it!
    The toggle option in HSTouch will come up when you have a set of VSPairs one with the .ControlUse property set to On and another set to Off. HSTouch does the toggle magic behind the scenes. I've never seen a guide I am afraid...
    My Plugins:
    Yeelight 3P | Nanoleaf 3P
      For whatever reason this doesn't seem to work.
       ' add an Off button and value
                              Dim Pair As VSPair
                              Pair = New VSPair(HomeSeerAPI.ePairStatusControl.Both)
                              Pair.PairType = VSVGPairType.SingleValue
                              Pair.Value = 0
                              Pair.Status = "Power Off"
                              Pair.Render = Enums.CAPIControlType.Button
                              Pair.Render_Location.Row = 2
                              Pair.Render_Location.Column = 1
                              Pair.ControlUse = ePairControlUse._Off            ' set this for UI apps like HSTouch so they know this is for OFF
                              hs.DeviceVSP_AddPair(ref, Pair)
                              GPair = New VGPair
                              GPair.PairType = VSVGPairType.SingleValue
                              GPair.Set_Value = 0
                              GPair.Graphic = "/images/HomeSeer/status/off.gif"
                              hs.DeviceVGP_AddPair(ref, GPair)
                              ' add an On button and value
                              Pair.Value = 1
                              Pair.Status = "Power On"
                              Pair.ControlUse = ePairControlUse._On            ' set this for UI apps like HSTouch so they know this is for lighting control ON
                              Pair.Render_Location.Column = 2
                              GPair = New VGPair
                              GPair.Set_Value = 1
                              GPair.Graphic = "/images/HomeSeer/status/on.gif"
        Will have to pass on that one then unfortunately as it should work, http://board.homeseer.com/showpost.p...6&postcount=30 explains it. As that post also eludes to, you could create your own Toggle button in the device also.
        My Plugins:
          I had the same issue for my plugin too before. The toggle option in HSTouch only came when the status description hold "On" or "Off". "Power Off" would not work for me.
          Wim
          -- Wim
            Good Information guys!
            I added the following to my device creation and it calls setIOMulti with my value, So I will probably have to write my own little toggle function but that sounds pretty easy. Both 9000 toggle On/Off and 9001 Toggle Power On/Off show up in the hstouch designer, so I could probably add as many toggle commands as I want named whatever I choose.
            'add a toggle vs pair
                                    Pair = New VSPair(ePairStatusControl.Both)
                                    Pair.Value = 9001
                                    Pair.Status = "Toggle Power On/Off"
                                    Pair.ControlUse = ePairControlUse.Not_Specified
