HS3 IR Remote Control IN Plugin
  • HS3 IR Remote Control IN Plugin
    Hi,
    Does soembedy know of a plugin that could be used to detect IR commands from a USB/RS-232 IR receiver connected to a Homeseer box, or planning to build something like this?
    Plan is to use my Harmony Ultimate remote to control Homeseer actions. And this seems to be the best way todo this.
    Was also looking to emulate a hue bridge which acts as a virtual device server, and trigger events on the states of the virtual; lamps but this is also quite complex and not ideal.
    regards
    Bart
    Regards Bart
    Win7 64Bit on Intel NUCI7 with SSD
    HSPRO 3.
    Devices; 1370 Events; 691
    Jon00 Scripts, JowHue, HSTouch, Plugwise, Z-wave, Ultranetatmo, Ultracam, PHlocation, BLUSBUIRT, MeiHarmony, Buienradar, MEiUnifi Pushover 3P, Random, Nest HSPhone and Blueiris
    Visonic Powermax Alarm System (HS3) Interface: http://www.domoticaforum.eu/viewtopic.php?f=68&t=11129
    The USB UIRT does IR code match triggering, Blade has a free plugin available for it. I have mine connected but have not yet tested it.
    My Plugins:
    Yeelight 3P | Nanoleaf 3P
      Mrhappy, great this is exactly what i am looking for, ordered mine rightaway
      Regards Bart
      HSPRO 3.
        The IP/Serial plugin can match codes received by a Global Cache GC-IRE.
        http://forums.homeseer.com/showthread.php?t=169753
          mrhappy,
          I have my USB UIRT and the blade plugin, however cant learn IRS. The learn window opens but not recieving, no led blinking.
          But in Debug log of the plugin I see recieved commands (led blinking also), also in girder its functioning fine. (led blinking also), any idea. I also posted in the blade plugin section.
          Bart
          Regards Bart
          HSPRO 3.
            Stupid..... Got it working now, needed to put my remote in learning mode really close to USB UIRT 1-2cm, and secondary problem i was using my harmony wich send the IR via HUB not via remote at that moment :O
            But it works
            Regards Bart
            HSPRO 3.
