Forcing ActionProcessPostUI
  • Forcing ActionProcessPostUI
    Gents
    I have a plugin with a combination of drop lists and text boxes (the Pushover plugin), I would like to be in a position to have a button that enables the ActionProcessPostUI to be called to effectively save the event data inputted.
    I do not wish to use the autoPostBack in the drop lists because of the fact that some fields are optional and using it results in a premature postBack (which needs the event to be re-opened and then the next matter selected), I have done this so far but it's use is less than ideal. Pressing the yellow up arrow does not appear to force ActionProcessPostUI to be called.
    I have tried adding a submit button and adding the HTML in ActionBuildUI into a form but the button does not appear to do anything in relation to submitting the form and the jQuery controls inside ActionBuildUI. Nothing gets called if I hit the submit button.
    Does anyone have any idea how I can submit the event manually? I don't know if I just have more differing controls than most but I would've thought that this would be possible and I am just struggling.
    Thanks...
    My Plugins:
    Yeelight 3P | Nanoleaf 3P
    Actionconfigured is responsible for closing the event
    If it ain't broke, don't fix it!
      OK - by whichever way be it configured or process - can you trigger this by a jQuery button to deal with the contents of the action rather than needing the autopostback? I only appear to get success by setting to true but I would like to try doing it manually because of the event collapsing without all of the controls being set.
      My Plugins:
        I've never done it any other way than using ActionBuildUI / ActionProcessPostUI / ActionConfigured. Like happnatious1 said, the ActionConfigured tells it to collapse the event or keep it open.
          Have it only return true when you have all of the fields set that you need. That allows the postback to add more controls based on an answer in a previous dropdown but it doesn't collapse until you have all of the fields you want.
          Jeff Farmer
          HS 3, HSPhone
            Cheers for the thoughts guys - I figured what was wrong in the end, you can have a button to update and force the process/configured (but not the collapse) - you do however have to specify the page name correctly!
            My Plugins:
