CAPIControl Do_Update
  • CAPIControl Do_Update
    I am writing scripts and using the CAPIControl to control devices. At times, a device that I am controlling may trigger another event or action that I don't want to trigger at this time. There is a Do_Update property in the CAPIControl that looks like, when set to false, will prevent any actions from triggering when devices are changed using the CAPIControl.
    My issue is, I cannot set the Do_Update property to false. However I do it I receive an error. Has anyone used this property before, or know of another way of accomplishing what I am trying to do?
    Interesting property - not seen that one before, I can set it to true the way I would do it but in my three seconds of testing the event always seems to fire - perhaps you could try and see what happens in your situation?
    Sub Main(ByVal Parm As Object)
        Try
            Dim CpReturn As CAPIControl
            CpReturn = hs.CAPIGetSingleControl(101, True, "On", False, True)
            hs.writelog("", CpReturn.Do_Update)
            CpReturn.Do_Update = False
            Dim ResponseEnum As CAPIControlResponse
            ResponseEnum = hs.CAPIControlHandler(CpReturn)
            hs.writelog("", ResponseEnum)
        Catch ex As Exception
            hs.writelog("", "Error: " & ex.message.tostring)
        End Try
    End Sub
    Or you could post your method and see whether something odd is in there...
    My Plugins:
    Yeelight 3P | Nanoleaf 3P
