JSON 401
  • JSON 401
    Hi,
    When trying to use the JSON api with credentials, I get a 401 depending on which browser I use.
    E.g.:
    http://pss@<ip>:<port>/JSON?request=getlocations
    Chrome: success
    IE: FAIL (401)
    Javascript: FAIL 401
    JS Code:
    var req = new XMLHttpRequest();
    req.open("GET", url, true);
    Any clue ?
    Best regads,
    Kriz
    If you are trying to embed the username and password in the URL then I was under the impression that this was a bit of a security hole that was closed up and to be avoided (?)...have you tried adding a basic auth http header? Or failing that the example given in the SDK implies you can pass the username/password in the HTTP arguments.
    My Plugins:
    Yeelight 3P | Nanoleaf 3P
