jqFileUploader not firing postBackProc
  • jqFileUploader not firing postBackProc
    Hello,
    I'm developing a plugin and want to use the jqFileUploader control. I cannot get the postback working on this control. When using a textbox it works fine; the postBackProc method is called.
    Any ideas where to look?
     stb.Append(FormStart("uploadform", "cc", "post"));
                    stb.Append("<input name='uploadaction' value='uploadactionvalue' type='hidden'>");
                    clsJQuery.jqFileUploader ul = new clsJQuery.jqFileUploader("uploader", this.PageName);
                    ul.toolTip = "Select Comfort Configuration file";
                    ul.values.Add("uploadfile", "true");
                    ul.AddExtension("*.cclx");
                    ul.label = "Upload";
                    stb.Append(ul.Build());
                    if (!string.IsNullOrEmpty(Util.Settings.ConfigFile))
                        stb.Append("Current configuration file: " + Util.Settings.ConfigFile);
                    stb.Append(PageBuilderAndMenu.clsPageBuilder.FormEnd());
