PI Func 'capabilities' ?
  • PI Func 'capabilities' ?
    Hi all,
    Sorry if this is documented somewhere; I couldn't seem to find it.
    When HSTouch server starts, it calls a Plugin function named "capabilities", then throws an error to the log as my default PI handler returns empty string.
    Error in log: "HSTouch had an Error retrieving the capabilities with Error = Conversion from string "" to type 'Integer' is not valid."
    I could not find any docs on what this is, or how to appropriately respond to it.
    Mike
    Have a look in the SDK manual here:
    http://homeseer.com/support/homeseer...pabilities.htm
    Nicolai L
      Originally posted by mikemack View Post
      Hi all,
      Mike
      Exactly as NicolaiL says - although I am not really sure it is used as much in HS3 as it was in HS2 (as now have device api's for thermostats/media). In HS2 you used to get IO, X10 or IR and IIRC there was some additional functions called in HS2 if you had X10/IR selected.
      My Plugins:
      Yeelight 3P | Nanoleaf 3P
        Guys,
        Thanks for the quick response! Sorry I was not more clear in my question -
        I do return the correct value for "Capabilities" API function, but I am getting a PluginFunction call with procName == "capabilities"
                public int Capabilities()
                    return (int)HomeSeerAPI.Enums.eCapabilities.CA_IO;
                public object PluginFunction(string procName, object[] parms)
                    // This is being invoked with "procName" == "capabilities"
        Mike
          Guys,
          Mike
          Yes this has come up before and not sure there was ever an answer, http://board.homeseer.com/showthread.php?t=175223
          It's odd that it does not come up more often, perhaps it is a specific set of capabilities/devices/API's that the HSTouch Server is looking for which in turn calls into PluginFunction looking for capabilties, or it is some legacy stuff left in by accident.
          My Plugins:
            Thanks!
            Submitted Bug 3184..
            Let's see..
