Doorbird (Video Doorbell) Plugin Request
  • Doorbird (Video Doorbell) Plugin Request
    I would like to request any Dev's that have interest in integrating a video doorbell into their home automation to consider writing a plugin for this product:
    http://www.doorbird.com/
    Here is a link to the API
    https://www.doorbird.com/api
    https://www.doorbird.com/downloads/api_lan.pdf?6
    I recently found out about this while researching Ring and SkyBell. Both of which have no API available and therefore limited integration with our Homeseer Automation setups.
    Also of note this unit also can be accessed with any NVR like BlueIris to view the video and supports PoE and wired connection so you don't have to rely on flakey WIFI
    Anyways I saw a thread or two of users that are currently using this product and thought if there was enough interest perhaps a developer could pick this project up.
    +1
    Sent from my iPhone
    Tom
      +1
      Hector
      Win.2003 OS, HS3
      MyTrigger,ACRF2,W800,Zwave
      AP800,Honeywell Stat
        Good to set some interest here, hopefully this will get enough attention that a dev would want to pick this up
          +1
            I would develop a plugin but I can't figure out the plugin documentation.
              +1
                Peter, has provided a detailed post of how he integrated the Doorbird to HS3 here.
                http://board.homeseer.com/showpost.p...1&postcount=40
                Tom
                  While I don't have a unit yet I would love to see this integrated with homeseer via plugin.
                  Guys let's post your top feature requests for the plugin. Hopefully one of the talented devs will pick it up!
                    I am considering a Doorbird as well given the access to the local stream. Looking at the LAN API document, there are not a lot of features exposed. It looks like the camera feeds can already be integrated with the existing camera plugins. Unless I'm missing something, everything else in that API document looks to be implementable with some simple scripts.
                    Cheers
                    Al
                    HS 3.0.0.548: 1965 Devices 1146 Events
                    Z-Wave 3.0.1.262: 122 Nodes on one Z-Net
                      It's way too expensive for me to justify buying one for the sake of writing a plugin but looking at that API as Al says it is fairly simple and you might not need a plugin (although it would be nicely packaged in one) as you can register a URL that could come through your local IP/MyHS and simply turn a device on/off when the doorbell event hits. A script to turn the other things on/off should work OK also.
                      My Plugins:
                      Yeelight 3P | Nanoleaf 3P
                        All a plugin would be is a nicely packaged set of scripts.
                          Nice to see this thread getting some activity and interest.
                          While I agree that most could be accomplished with various different scripts, and with the posting shared it seems we have a workable solution. I was thinking that there could be Custom Triggers and Conditions that could be setup for use with events etc.
                          Also not all of us are scripting gurus. This appears to be the only such video doorbell with integration options. In My opinion it is worth the cost and having a neatly packaged plugin for tighter integration would be worth it.
                          I figured I would post here to see if there was interest by any developers. I would try to write one but unfortunately I don't possess the software coding skills
                            It would be fantastic if there was a plugin. I would write one but the plugin documentation is awful. I hope we get a proper plugin soon, doorbird has even integrated with control4.
                              I agree!
