Plugin Request 4: Notes
  • Plugin Request 4: Notes
    Hello
    Please can I request a plugin; which simply allows a notes section on the Web Server (like a yellow sticky) so people can make a note ie so I can record the work i need to do on my HomeSeer Web Server.
    But further interaction where these can be accesible from HSTouch & amended within HSTouch, and a next and back button can navigate through the note entries.
    I imagine the fields in device manager would be something like:
    Next Note Button / Previous Note Button
    Note Selected: 1
    Total Notes: 7
    Note Contents: Text
    Thank you
    This is not exactly what you are looking for, but may do in the mean time: http://board.homeseer.com/showthread.php?t=113128
    Cheers
    Al
    HS 3.0.0.532: 1963 Devices 1141 Events
    Z-Wave 3.0.1.261: 122 Nodes on one Z-Net
      Thanks Al, I will give this a shot initially. Sounds like a temporary good idea for sure.
      Thank you
        You may not be aware but you can also write notes against every virtual device on the device management page as shown below. This is stored in the Homeseer database.
        Jon
          And the same is there for events.
          Randy Prade
          Aurora, CO
          Prades.net
            I was not aware of it
            Can you access a virtual devices note via HSTouch?
            Where is the notes in the events?
              For events:
              -- Wim
                No, only via the web interface.
                Jon
                  I just wanted to bump this up for consideration for a developer looking for a project....
                  ModHistory is very good - thanks Al, and others for notes which be added to HS3 devices and events.
                  However I am still looking for a plugin which can be used in HSTouch; to record and write notes - and recall them. And possibly save these notes as a virtual device.
                  What I am thinking of is something like:
                  Virtual Device:
                  [ Current Note Textbox ][Next, Previous, Add, Edit, Delete]
                  --[Note 1 Text][Edit, Delete]
                  --[Note 2 Text][Edit, Delete]
                  --[Note 3 Text][Edit, Delete]
                  Then I can make a yellow sticky image for HSTouch and have it shown the current text, a next and previous button can be used to scroll through the note object 1,2,3 and a delete, edit and add will allow additional.
                  Thank you all
