Need help with hs.pluginfunction
  • Need help with hs.pluginfunction
    SOLVED!!!!!
    HI all ,
    I post this here because its part of the plugin..
    im using the plugwise plugin , but there is one thing what doesnt work , and maybe someone knows what im doing wrong ,
    this is written in the pdf
    The plugin support 2 scripting function:
    • hs.PluginFunction("Plugwise Pro", "", "GetCurrentPower", {DeviceRef})
    • hs.PluginFunction("Plugwise Pro", "", "GetTotalPower", {DeviceRef})
    when i use that it doesnt work
    i tried this in emidiate script command:
    PHP Code:
    &hs.PluginFunction("Plugwise Pro""""GetTotalPower", {"3383"})
    hs.PluginFunction("Plugwise Pro""""GetTotalPower", {3383})
    hs.PluginFunction("Plugwise Pro""""GetTotalPower", ("3383"))
    hs.PluginFunction("Plugwise Pro""""GetTotalPower", (3383))
    hs.PluginFunction("Plugwise Pro""""GetTotalPower""3383")
    hs.PluginFunction("Plugwise Pro""""GetTotalPower"3383
    i get the following errors
    PHP Code:
    Running script(2) &hs.PluginFunction("Plugwise Pro""""GetTotalPower", {3383}), init errorInvalid character
    and this
    PHP Code:
    Running script(2) &hs.PluginFunction("Plugwise Pro""""GetTotalPower",3383), init errorInvalid procedure call or argument'hs.PluginFunction'
    Preferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
    HS3Pro 3.0.0.531 on windows 7 ultimate X64 on hp quadcore laptop 8 GB.
    Have you tried the commands in a .vb script? Maybe try:
    &nhs.PluginFunction("Plugwise Pro", "", "GetTotalPower", {3383})
    or &hs.PluginFunction "Plugwise Pro", "", "GetTotalPower", {3383}
    Cheers
    Al
    HS 3.0.0.548: 1976 Devices 1156 Events
    Z-Wave 3.0.1.262: 123 Nodes on one Z-Net
      i did try the first one and i get this
      PHP Code:
      Error 1    Running script C:\Program Files (x86)\HomeSeer HS3\Temp\K1.vb :Exception has been thrown by the target of an invocation.Method invocation failed because 'Public Overrides Function PluginFunction(plugname As String, pluginstance As String, func As String, parms As System.Object()) As System.Object' cannot be called with these argumentsArgument matching parameter 'parms' cannot convert from 'Integer()' to 'Object()'
      Cheers
      Al
        i found it :
        Sub Main(ByVal parm As String)
        dim MeterDev As string = hs.PluginFunction("Plugwise Pro", "", "GetTotalPower", {"3382"})
        hs.writelog("script", "" & MeterDev)
        End Sub
        this one works !
