Linux Mono Error - Z-Wave drivers
    Currently using Z-Wave V 3.0.1.80. I know I have to update it.
    Updating OS this morning (IE: apt-get update / upgrade) saw the following error.
    :~# mono -V
    Mono JIT compiler version 4.6.2 (Stable 4.6.2.16/ac9e222 Tue Jan 3 12:12:14 UTC 2017)
    Running Jessie here on the RPi2.
    Anyone else seeing this?
    Processing triggers for ca-certificates (20141019+deb8u2) ...
    Updating certificates in /etc/ssl/certs... 0 added, 0 removed; done.
    Running hooks in /etc/ca-certificates/update.d....Updating Mono key store
    Mono Certificate Store Sync - version 4.8.0.0
    Populate Mono certificate store from a concatenated list of certificates.
    Copyright 2002, 2003 Motus Technologies. Copyright 2004-2008 Novell. BSD licensed.
    Error: System.MissingMethodException: Method 'Mono.Security.X509.X509StoreManager.get_NewCurrentUser' not found.
    at Mono.Tools.CertSync.Main (System.String[] args) [0x0002b] in <e14d5123bc22484f8e0510200156fa93>:0
    Done
    Rebooted
    Did another update and upgrade and it showed 150 mono upgrades. Did a dist-upgrade. Rebooted and all looks fine now.
    - Pete
    Auto mator
    HSTouch on Intel tabletop tablets - Asus AIO
    I did get the 150 mono updates the other day. Took a backup image of the sd first. Upgrade only updated the ca-certificates package, (don't remember getting that error). Then I did the dist-upgrade and it went fine, hs3 running smoothly.
