It took me a while here to update to V.342 which I think was the second version of HS to integrate Homeseer Touch.
I have been sitting on the fence relating to updating beyond V.342 lately.
That said per your post here disabled Homeseer Touch in the Tools> Setup > network page and the switch here does appear to be working.
A partial clip of the Homeseer logs showing a disconnect of all of the LAN connected clients.
Sep-07 11:48:44 AM HSTouch Server HSTouch was shutdown
Sep-07 11:48:44 AM HSTouch Server Client ICS-Jog-XPE-10:ICS-Jog-XPE-10 (192.168.244.225/4617) has raised LineDisconnected.
Sep-07 11:48:44 AM Speaker Speaker host disconnected, Name: ICS-HS3PRO IP address: 192.168.244.171
Sep-07 11:48:44 AM ASR Speaker Client speech recognition stopped
Sep-07 11:48:44 AM HSTouch Server Client ICS-Jog-XPE-10 named ICS-Jog-XPE-10 has DISCONNECTED.
Sep-07 11:48:44 AM HSTouch Server Client ICS-Jog-XPE-05:ICS-Jog-XPE-05 (192.168.244.205/3372) has raised LineDisconnected.
Sep-07 11:48:44 AM HSTouch Server Client ICS-Jog-XPE-02:ICS-Jog-XPE-02 (192.168.244.202/1775) has raised LineDisconnected.
On and on here until all of the clients got disconnected.
Re-enabled HSTouch and all of them connected fine looking at the Homeseer logs.
In a quickie recap here using:
- HomeSeer Pro / Lite HS3 Edition 3.0.0.342 (Linux)
- HSTouch Windows Clients V.36
I understand that V.356 is or may be going to a standard release.
Updated Homeseer Pro machine running 3.0.0.342 (Linux) to HS3 Pro Edition 3.0.0.356 (Linux).
Noticed I have an archive of HS3 Pro Edition 3.0.0.348 (Linux) from August 9, 2017. Not sure why I went back to .342.
Starting logs show no errors and all clients connected fine.
Shut off Homeseer Touch via switch. Logs showing disconnect are less chatty kathy. Saw Homeseer Speaker client shut off 4 times.
Sep-07 1:57:32 PM HSTouch Server HSTouch was shutdown
Sep-07 1:57:32 PM HSTouch Server Client ICS-Jog-XPE-05:ICS-Jog-XPE-05 (192.168.244.205/3594) has raised LineDisconnected.
rest of HSTouch clients
Sep-07 1:57:32 PM Speaker Speaker host disconnected, Name: ICS-HS3PRO IP address: 192.168.244.171
I do not understand 4 speakers being disconnected here as there is only one running for HSPro machine.
Sep-07 1:57:32 PM ASR Speaker Client speech recognition stopped
Enabled Homeseer touch and everything connected fine.
Will let this run a bit and upgrade Homeseer 3 lite (zee) to same version.
