Discussions related to HS3 Beta build 3.0.0.449
    Originally posted by cp1983 View Post
    Running the tibber plugin and memory usage goes to 7.9% just after 3 days. Without tibber it is 3.9% after 5 days. (see screenshots)
      Rich,
      do both Timers.Timer and Threading.Timers have the same memory leak on Mono?
        That I don't know, but I am not using either one any longer.
        Originally posted by Moskus View Post
        Rich,
          Sorry if this has been covered somewhere, I've looked all over for it. I thought I saw a posting about a fix for Alexa smart devices not being discovered in one of the recent betas after .435? Is that correct?
          I've had quite a bit of trouble with the Alexa integration lately, thinking part of it was due to the server issues and Prime day but thought I would check.
          Thank you!
          HS4 4.2.6.0 &HSTouch Designer 3.0.80
          Plugin's:
          weatherXML, Jon00 Alexa Helper, Network Monitor, MyQ, Z-Wave
            No issues that I am aware of. If you have a repeatable issue, open a ticket and we will assist.
            Thank you!
              I see the same thing with Devices not showing up in the Alexa app. It turns out, it just takes ALOT OF TIME. Hours.
              I don't know why. But i started with .435 here too.
                Sep-14 7:15:00 AM Log Error 32785 failed to be deleted from the logging database - check the log for details or restart HS3 to attempt to resolve this issue.
                Sep-14 7:15:00 AM Delete (Log/Date) Error: database disk image is malformed database disk image is malformed
                Error Delete (Log/Date) Error: database disk image is malformed database disk image is malformed
                Current Date/Time: 9/14/2018 8:08:38 AM
                HomeSeer Version: HS3 Pro Edition 3.0.0.449
                Linux version: Linux hs3 4.15.0-34-generic #37-Ubuntu SMP Mon Aug 27 15:21:48 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux System Uptime: 0 Days 0 Hours 40 Minutes 45 Seconds
                IP Address: 192.168.42.9
                Number of Devices: 403
                Number of Events: 95
                Available Threads: 399
                HSTouch Enabled: True
                Event Threads: 0
                Event Trigger Eval Queue: 0
                Device Exec Queue: 0
                HSTouch Event Queue: 0
                Email Send Queue: 0
                Anti Virus Installed:
                Enabled Plug-Ins
                3.0.2.0: AquaConnect
                3.0.0.56: DSC Security
                3.0.1.10: Kodi
                3.4.9.0: mcsMQTT
                1.2.0.0: Monoprice Amp
                3.0.1.109: PHLocation
                3.0.6629.22233: Ultra1Wire3
                3.0.0.88: weatherXML
                0.0.0.6: YAMAHA-RECEIVER
                3.0.1.190: Z-Wave
                https://forums.homeseer.com/forum/de...plifier-plugin
                  We try to recover from these at start up, if not, then shut down HS and delete the log file in the Logs folder.
                  As an FYI, we are getting rid of SQLite for the log database and moving to something with a simple format that is more robust.
                  Event Threads: 0
                  Email Send Queue: 0
                  Enabled Plug-Ins
                  3.0.1.10: Kodi
                  3.4.9.0: mcsMQTT
                  3.0.1.190: Z-Wave
                    Why getting rid of the most deployed database in the world?
                    John
                      John
                      Source?
                        Source?
                        https://www.sqlite.org/index.html
                        Wikipedia:
                        https://en.wikipedia.org/wiki/SQLite
                        SQLite is a popular choice as embedded database software for local/client storage in application software such as web browsers. It is arguably the most widely deployed database engine, as it is used today by several widespread browsers, operating systems, and embedded systems (such as mobile phones), among others.[6] SQLite has bindings to many programming languages.
                        John
                          Quote from sqllite website:
                          SQLite is likely used more than all other database engines combined.
                          From Donald Trumps website:
                          I'm the bestest president ever.
                            SQLite is likely used more than all other database engines combined. just being used a lot doesn't make it the best choice.
                            Most likely outcome.... Best in 60 years forsure
                              Okay, THAT was funny!
