New Error on .460
    #46
    simonmason Which plugins do you have active?
      #47
      It would be very good to know what the cause is. I get about 50 each time HS is restarted, all Type: 32 and all in the same second
      Jan-04 5:08:10 PM         Warning    Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
      This has been going on since last year, possibly before. I just ignore them.
      I also get them intermittently during normal operation, but have never noticed anything with the function of the system. They are predominantly Type 1024, 2048 and 16384.
      Randy Prade
      Aurora, CO
      Prades.net
        #48
        I get about 4 to 7 of Type 32 every time HS is restarted and then the others many times during the day, but very few if any at night. I see many times where ImperiHome is displaying the wrong info, even when refreshing, but when I look at HS, the device value/status is correct, so I'm suspecting that the full queue is causing device changes to not be properly reflected in IH. Given there are way fewer at night in my case, I am suspecting a plugin or two and have contacted one of the plugin developers to troubleshoot.
          #49
          Same here. But just 1-3.
          I tried to. Disable and enable all plugin. With a hs3 restart each time.
          but was not able to identify a specific plugin in cause.
          rjh
          so i Assume it is a hs3 bug
            #50
            It would be better if we could know more about what is actually happening. Looking at mine over the last 2 weeks and filtering on Type 16384 i have had 71 and they also appear to happen only during the day.
            Jan-02 4:08:58 PM         Warning    Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
            Jan-02 2:21:58 PM         Warning    Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
            Jan-02 2:21:57 PM         Warning    Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
            Jan-02 2:21:54 PM         Warning    Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
            Jan-02 2:21:53 PM         Warning    Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
            Jan-02 11:00:16 AM         Warning    Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
            Jan-02 9:00:19 AM         Warning    Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
            Jan-02 9:00:14 AM         Warning    Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
            Jan-02 9:00:13 AM         Warning    Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
            Jan-02 9:00:11 AM         Warning    Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
            Jan-02 9:00:08 AM         Warning    Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
            Jan-02 8:00:13 AM         Warning    Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
            Jan-01 9:00:12 AM         Warning    Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
            Jan-01 9:00:11 AM         Warning    Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
            Dec-31 6:04:57 PM         Warning    Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
            Dec-31 6:04:56 PM         Warning    Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
            Dec-29 3:38:30 PM         Warning    Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
            Dec-18 10:00:23 AM         Warning    Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
            Dec-18 10:00:16 AM         Warning    Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
            Dec-18 9:00:14 AM         Warning    Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
            Dec-18 9:00:13 AM         Warning    Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
            Dec-18 9:00:08 AM         Warning    Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
            Dec-18 7:00:14 AM         Warning    Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
            Dec-17 3:00:14 PM         Warning    Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
            Dec-17 3:00:08 PM         Warning    Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
            Dec-17 12:00:12 PM         Warning    Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
            Dec-17 12:00:11 PM         Warning    Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
            Dec-17 12:00:10 PM         Warning    Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
            Dec-17 12:00:09 PM         Warning    Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
            Dec-17 10:00:17 AM         Warning    Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
            Dec-17 10:00:14 AM         Warning    Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
            Dec-17 9:00:17 AM         Warning    Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
            Dec-16 5:32:06 PM         Warning    Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
            Dec-16 5:32:05 PM         Warning    Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
            Dec-16 2:42:58 PM         Warning    Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
            Dec-16 1:45:14 PM         Warning    Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
            Dec-15 6:10:34 PM         Warning    Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
            Dec-15 6:10:33 PM         Warning    Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
            Dec-15 5:19:25 PM         Warning    Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
            Dec-15 5:19:24 PM         Warning    Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
            Dec-15 5:17:03 PM         Warning    Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
            Dec-15 5:17:02 PM         Warning    Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
            I have but don't use ImperiHome and rarely use HSTouch, so I have no idea if they are not in sync. My plug-ins:
            Randy Prade
            Aurora, CO
            Prades.net
              #51
              Here are the numbers I've had since Dec 16th:
              Type 2: 5
              Type 32: 52
              Type 64: 145
              Type 1024: 158
              Type 2048: 60
              Type 16384: 717
              Total: 1137
              And my current enabled plugins:
              3.3.0.0: APCUPSD
              1.0.65.0: BLLED
              2.0.26.0: BLTVGuide
              3.0.0.29: Chromecast
              3.0.0.56: DSC Security
              3.0.0.54: EasyTrigger
              1.491.16343.807: Homekit bridge
              3.0.1.3: IFTTT
              3.0.0.29: ImperiHome
              1.5.0.0: MQTT
              1.0.5687.23871: MySensors
              3.0.1.125: PHLocation
              0.0.0.45: Pushover 3P
              3.0.0.2: Random
              1.0.0.7: Restart
              30.0.0.37: RFXCOM
              3.0.6.7: SDJ-Health
              3.2.0.3: SqueezeBox
              3.0.6629.22233: Ultra1Wire3
              3.0.6551.16959: UltraGCIR3
              3.0.6644.26753: UltraLog3
              3.0.6413.20219: UltraNetCam3
              3.0.6196.17229: UltraPioneerAVR3
              3.0.0.88: weatherXML
              3.0.0.44: X10
              3.0.1.249: Z-Wave
                #52
                On my old system I was getting a lot of the "Dropping event callbacks due to full queue" errors all throughout the day. This caused numerous errors with my HSTouch deployments throughout the house. They seemed to always be out of sync. Our old computer system was around 4 years old and definitely underpowered, so around Christmas time, we decided to upgrade. We went from a ASUS VM42-S075V 2957U (2 physical cores) to a ASUS VC66-CB5018ZN VivoMini PC Intel Core i5-8400 (6 physical cores). This upgrade greatly improved our home automation experience. The old system was just overloaded for all that I had running on it. The CPU was almost always above 70%, and a lot of the time above 90% if not completely maxed out. This heavy load increased the number of "Dropping event callbacks due to full queue" errors in the log. Since upgrading to a new system, I rarely ever see any of these notifications in the log, but do see them occasionally. The new system rarely gets above 10% utilization. As Randy indicated, upon restart I do see handfull of the errors, but that is usually for a very short period.
                These are my numbers since December 16th 2018
                Type 2: 0
                Type 32: 2
                Type 64: 33
                Type 1024: 145
                Type 2048: 44
                Type 16384: 0
                Total: 224
                I did notice that if "Show Source Thread" is checked on the HomeSeer Log page, the logs for "Dropping event callbacks due to full queue" mostly show a source similar to the following "(System)_23-Dec-2018 14:30:44.8418_Scheduler Timer"
                I do have a few timers, 19 in all. Most only run to track certain durations, nothing really spectacular. There are 4 that run most of the time that track the duration between heartbeats on my smoke detectors.
                There should be a way to understand what is going on here and why... Hopefully we can get some answers or something to provide more information.
                Billy Draper
                  #53
                  I've seen those as well and like others only shortly after restarting.
                    #54
                    Jan-04 17:34:31 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                    Jan-04 16:54:43 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                    Jan-04 16:44:33 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                    Jan-03 22:51:38 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                    Jan-02 20:43:37 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                    Jan-02 18:21:24 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                    Jan-02 14:25:19 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                    Jan-02 13:46:58 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                    Jan-02 13:34:26 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                    Jan-01 01:45:55 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                    Dec-30 22:01:20 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                    Dec-28 21:59:45 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                    Dec-27 22:13:43 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                    Dec-22 04:25:36 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                    Dec-19 04:23:38 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                    Dec-18 17:49:10 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                    Dec-18 17:01:42 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                    Dec-15 02:56:42 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                    Dec-15 02:42:15 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                    Dec-14 20:47:30 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                    Dec-11 22:58:50 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                    Dec-11 22:51:33 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                    Dec-10 20:30:55 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                    Dec-09 17:25:21 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                    Dec-09 00:27:55 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                    Dec-07 18:27:16 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                    Dec-06 15:57:42 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                    Dec-06 00:29:34 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                    Dec-03 18:39:50 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                    Dec-02 21:26:09 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                    Nov-29 08:20:52 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                    Nov-28 22:46:35 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                    Nov-28 22:37:19 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                    Nov-28 22:30:14 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                    Nov-28 22:13:11 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                    Nov-28 22:08:43 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                    Nov-28 22:05:25 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                    Nov-28 16:16:52 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                    Nov-28 16:00:24 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                      #55
                      Some missing here but they were all type 32
                      Nov-27 23:34:45 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                      Nov-27 23:27:14 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                      Nov-27 22:41:12 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                      Nov-27 22:32:59 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                      Nov-27 22:02:52 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                      Nov-27 21:58:34 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                      Nov-27 21:52:08 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                      Nov-27 21:42:16 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                      Nov-27 21:15:34 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                      Nov-27 20:53:21 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                      Nov-27 19:38:48 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                      Nov-27 19:34:44 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                      Nov-27 17:39:09 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                      Nov-26 21:58:17 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                      Nov-26 04:15:55 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                      Nov-26 04:09:38 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                      Nov-26 04:06:29 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                      Nov-26 04:00:32 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                      Nov-26 03:57:42 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                      Nov-26 03:55:34 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                      Nov-26 03:48:21 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                      Nov-26 03:24:52 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                      Nov-26 03:24:51 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                      Nov-26 03:09:31 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                      Nov-26 03:07:30 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                      Nov-26 03:04:41 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        #56
                        Nov-25 06:50:18 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:50:01 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:50:00 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:49:54 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:49:51 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:49:50 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:49:48 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:49:39 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:49:39 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:49:35 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:49:34 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:49:31 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:49:29 Warning Dropping event callbacks due to full queue (Type: 2) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:49:28 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:49:28 Warning Dropping event callbacks due to full queue (Type: 2) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:49:27 Warning Dropping event callbacks due to full queue (Type: 2) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:49:26 Warning Dropping event callbacks due to full queue (Type: 2) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:49:18 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:49:16 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:19:18 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:19:15 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:19:00 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:18:54 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:18:52 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:18:51 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:18:50 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:18:48 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:18:35 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:18:18 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:18:13 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:18:09 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:18:08 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:18:07 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:18:04 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:17:52 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:17:48 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:17:46 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:17:35 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:17:18 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:16:48 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:16:46 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:16:42 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:16:42 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:16:35 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:16:18 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:16:18 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:16:13 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:16:10 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:16:00 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:15:48 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:15:44 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:15:38 Warning Dropping event callbacks due to full queue (Type: 64) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:15:35 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:15:18 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:15:06 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:14:48 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:14:45 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:14:45 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:14:42 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:14:41 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:14:39 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:14:35 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:14:34 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:14:18 Warning Dropping event callbacks due to full queue (Type: 64) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:14:02 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:13:55 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:13:52 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:13:49 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:13:48 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:13:41 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:13:35 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:13:35 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:13:30 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:13:29 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:13:28 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:13:24 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:13:22 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:13:00 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:12:59 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:12:58 Warning Dropping event callbacks due to full queue (Type: 64) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:12:54 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:12:48 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:12:48 Warning Dropping event callbacks due to full queue (Type: 64) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:12:36 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:12:35 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:12:33 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:12:32 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:12:31 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:12:29 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:12:27 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:12:26 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:12:24 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:12:22 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:12:18 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:12:15 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:12:10 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:12:09 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:12:03 Warning Dropping event callbacks due to full queue (Type: 64) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:12:03 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:11:59 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:11:58 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:11:56 Warning Dropping event callbacks due to full queue (Type: 2) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:11:55 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:11:54 Warning Dropping event callbacks due to full queue (Type: 2) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:11:51 Warning Dropping event callbacks due to full queue (Type: 2) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:11:50 Warning Dropping event callbacks due to full queue (Type: 2) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:11:48 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:11:41 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:03:18 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:03:04 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:03:02 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:02:48 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:02:42 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:02:37 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:02:35 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:02:30 Warning Dropping event callbacks due to full queue (Type: 64) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:02:18 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:02:08 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:02:03 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:02:01 Warning Dropping event callbacks due to full queue (Type: 2) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:01:59 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:01:58 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:01:48 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:01:39 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:01:35 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:01:26 Warning Dropping event callbacks due to full queue (Type: 64) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:01:18 Warning Dropping event callbacks due to full queue (Type: 64) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:01:02 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:01:00 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:00:58 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:00:39 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:00:35 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:00:33 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:00:30 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:00:27 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:00:22 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:00:01 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 06:00:00 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:59:50 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:59:48 Warning Dropping event callbacks due to full queue (Type: 64) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:59:40 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:59:39 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:59:38 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:59:35 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:59:30 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:59:24 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:59:18 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:59:18 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:59:15 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:59:12 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:58:48 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:58:39 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:58:38 Warning Dropping event callbacks due to full queue (Type: 2) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:58:35 Warning Dropping event callbacks due to full queue (Type: 64) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:58:26 Warning Dropping event callbacks due to full queue (Type: 64) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:58:18 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:58:14 Warning Dropping event callbacks due to full queue (Type: 64) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:58:09 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:58:07 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:58:06 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:57:48 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:57:42 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:57:41 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:57:38 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:57:35 Warning Dropping event callbacks due to full queue (Type: 2) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:57:25 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:57:24 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:57:23 Warning Dropping event callbacks due to full queue (Type: 2) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:57:20 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:57:19 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:57:18 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:57:17 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:57:16 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:57:15 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:57:14 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:57:11 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:57:10 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:57:09 Warning Dropping event callbacks due to full queue (Type: 2) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:57:08 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:57:07 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:57:06 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:57:06 Warning Dropping event callbacks due to full queue (Type: 64) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:57:05 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:57:04 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:57:02 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:57:01 Warning Dropping event callbacks due to full queue (Type: 64) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:57:00 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:57:00 Warning Dropping event callbacks due to full queue (Type: 64) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:56:58 Warning Dropping event callbacks due to full queue (Type: 64) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:56:56 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:56:55 Warning Dropping event callbacks due to full queue (Type: 64) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:56:54 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:49:48 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:49:45 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:49:44 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:49:42 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:49:41 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:49:39 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:49:36 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:49:35 Warning Dropping event callbacks due to full queue (Type: 64) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:49:27 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:49:21 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:49:19 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:49:18 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:49:12 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:49:10 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:49:09 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:49:06 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:49:00 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:48:57 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:48:53 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:48:51 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:48:48 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:48:48 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:48:40 Warning Dropping event callbacks due to full queue (Type: 2) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:48:39 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:48:35 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:48:18 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:48:17 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:48:16 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:48:16 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:48:15 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:48:14 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:48:12 Warning Dropping event callbacks due to full queue (Type: 2) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:48:12 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:48:09 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:48:08 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:48:07 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:48:06 Warning Dropping event callbacks due to full queue (Type: 2) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:48:05 Warning Dropping event callbacks due to full queue (Type: 2) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:47:55 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:36:16 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:36:15 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:36:15 Warning Dropping event callbacks due to full queue (Type: 2) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:36:13 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:36:12 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:36:11 Warning Dropping event callbacks due to full queue (Type: 2) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:36:10 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:36:09 Warning Dropping event callbacks due to full queue (Type: 2) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:36:06 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:36:03 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:36:01 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:36:00 Warning Dropping event callbacks due to full queue (Type: 2) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:35:58 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:35:57 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:35:53 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:35:52 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:35:52 Warning Dropping event callbacks due to full queue (Type: 2) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:35:51 Warning Dropping event callbacks due to full queue (Type: 2) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:35:49 Warning Dropping event callbacks due to full queue (Type: 2) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:35:48 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:35:46 Warning Dropping event callbacks due to full queue (Type: 2) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:35:45 Warning Dropping event callbacks due to full queue (Type: 2) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:35:43 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:35:43 Warning Dropping event callbacks due to full queue (Type: 2) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:35:41 Warning Dropping event callbacks due to full queue (Type: 2) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:35:40 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:35:39 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:35:39 Warning Dropping event callbacks due to full queue (Type: 2) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:35:35 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:35:34 Warning Dropping event callbacks due to full queue (Type: 2) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:35:33 Warning Dropping event callbacks due to full queue (Type: 2) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 05:35:30 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 04:40:55 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 04:40:53 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 04:40:53 Warning Dropping event callbacks due to full queue (Type: 2) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 04:40:48 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 04:40:35 Warning Dropping event callbacks due to full queue (Type: 64) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 04:39:51 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 04:39:49 Warning Dropping event callbacks due to full queue (Type: 2) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 04:39:48 Warning Dropping event callbacks due to full queue (Type: 64) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 04:39:42 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 04:39:35 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 04:39:19 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 04:39:18 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 04:39:14 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 04:38:59 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 04:38:58 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 04:38:55 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 04:38:48 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 04:38:47 Warning Dropping event callbacks due to full queue (Type: 64) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 04:38:35 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 04:38:27 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 04:38:27 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 04:38:25 Warning Dropping event callbacks due to full queue (Type: 64) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 04:38:25 Warning Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 04:38:23 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 04:38:22 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 04:38:20 Warning Dropping event callbacks due to full queue (Type: 64) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 04:38:18 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 04:38:17 Warning Dropping event callbacks due to full queue (Type: 64) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 04:38:16 Warning Dropping event callbacks due to full queue (Type: 2) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 04:38:15 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 04:38:14 Warning Dropping event callbacks due to full queue (Type: 64) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 04:38:13 Warning Dropping event callbacks due to full queue (Type: 2) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 04:38:12 Warning Dropping event callbacks due to full queue (Type: 2) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 04:38:09 Warning Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 04:38:08 Warning Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 04:38:07 Warning Dropping event callbacks due to full queue (Type: 64) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-25 04:37:59 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-22 22:08:59 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-19 23:42:14 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                        Nov-18 22:38:13 Warning Dropping event callbacks due to full queue (Type: 32) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                          #57
                          This is interesting. The one thing I know that I can generally do to cause this issue is to run an event I have that turns all lights off around the house. This usually kicks off the problem because of the number of devices being updated all at once. However, I saw this in the log today when I ran a rescan on one node. So I am starting to wonder if there is a connection between the issue and the z-wave plugin. Of course all I have is circumstantial information which which to make this connection. But there is no other way to diagnose this.
                            #58
                            That looks like the plugin crashed, its very common to see the queue issue when a plugin crashes as it takes a bit for HS to realize and meanwhile those queues fill up.... It is probably NOT related to your ongoing issue unless you see constant zwave plugin crashes.
                              #59
                              Bill, I too was suspecting a zwave plugin issue. But got the error without the plugin activated. I know... I should have documented my ''debug'' more.
                              In my case , do you think it could be a plugin crash at boot?..and then the plugin restart by itself without logs?
                              If you look at my system in my signature, I do not think it could be a resources issue?
                              If it is , maybe hs3 is limiting the permitted load in a ''static manner'' ( homogeneously across all hs3 system), and if it's too high , it drops the event callback?
                              I searched the forum almost two months ago for this error, and was not able find a satisfactory answer.
                              edit :
                              I don't know if that cpu time is normal with the zwave plugin.
                                #60
                                Matt, I was responding to the particular issue above where the plugin clearly crashed in this instance. Generally (as I stated above) when this occurs it either means one buggy plugin is way too slow or a few medium plugs together are too slow. The system is generating events faster than they can be dispatched. Until Rich adds better logging, its a bit of a hunting game. Ive been trying to come up with a way to narrow this down, but I'm a bit stumped. I guess I could write a tool to hammer certain types of config changes/device changes, from the above it sounds like such a tool on at least his system (and maybe yours) would start seeing the error as if the zwave did a huge number of operations. From there its still a hunting game trying to find the guilty plugins. If Rich game me access, I could probably instrument this in an afternoon, I really wish parts of the engine where opensource....
