Many times I've seen a given HSPI_ZWave.exe process hogging a lot of CPU time. I'd like to know which device but I haven't found anyway to relate a Wave device to a given process. While I was watching processes run I notice that one plugin, RaspberryIO.exe, has a way to ID what it's controlling. In added a instance=name on the command line. Command line switches are normally listed when you list processes at least on Linux.
I was wondering if it would be possible to add a simular parameter to the HSPI_ZWave.exe processes even if the parameter was a dummy parameter just used so we could see what device that process is handling? Maybe something like ReferenceID="ReferenceID" so we can figure it out.
It might be nice to use to make this a standard for all processes HS3 starts so all devices can be identified.
If there is already a way to do this could someone please post it.
