Please note that HS3 is a totally new program with many internal changes to device and event formats. It is not possible to do a straight import from HS2 to HS3. We have created an import tool that will import the following. To run this tool, you should have HS2 and HS3 installed on the same system. Run the tool and it should find both your HS2 and HS3 databases. The tool imports the following:
* All your event names and group names
* The following event triggers:
Absolute time
Manual
Sunrise with offset
Sunset with offset
Recurring
* The following event actions:
Launch App
Audio control
Play wave file
Speak
Wait
* Your Z-Wave security key is imported so Z-Wave locks do not have to re-added to the network (just re-scanned)
After the import, you will need to edit your events and set the correct triggers and actions.
Devices are not imported. To import your Z-Wave devices, enable the Z-Wave plug-in and to an Import/Scan. Then edit the devices as needed.
Note that the scripting API has changed so existing HS2 scripts will not run without modifications. The biggest change that devices are now referenced by the unique reference # so functions that used HouseCode/UnitCode to reference devices have changed. We will post a change list of which functions have changed.
Here is the HS2 to HS3 import tool:
ftp://ftp.homeseer.com/updates/Beta/...pHS3Import.exe
HS3 Plugins
The following plugins are currently available for HS3 and were developed by HomeSeer. These plugins are in the HS3 updater now:
Z-Wave
X10 (supports TI103 and CM11A)
CurrentCost
RCS Serial Thermostats
SQ Blaster
Global Cache (GC-100 and iTach)
ADIO-100 digital in/out
Rain/Relay8
DSC Security Panel
HAI OmniStat Thermostat
HSTouch Server
Third Party Plugins:
Most of Blade's plugins
More third party plugins are in development and will be available soon.
Absolute time
Manual
Sunrise with offset
Sunset with offset
Recurring
Launch App
Audio control
Play wave file
Speak
Wait
HS3 Plugins
Z-Wave
CurrentCost
SQ Blaster
Rain/Relay8
DSC Security Panel
HSTouch Server
