How to use HS.Plugin?
    I'm trying to call the API to access a plugin but am getting an error? Is this done differently with HS3? I'm trying to test this by just running it through the "Immediate Script Command" form...
    thanks
    7/8/2013 10:18:34 PM Error Running script, init error: Object doesn't support this property or method: 'hs.Plugin'
    7/8/2013 10:18:34 PM System Control Panel Immediate Script: &hs.Plugin("BLRussound").EnableDebugLogging()
    Try this:
    hs.PluginFunction("BLRussound", "", "EnableDebugLogging", Nothing)
    Cheers,
    Bob
      Originally posted by Blade View Post
      Try this:
      Thanks for the help. I tried and got the following...
      7/9/2013 9:20:38 PM Error Running script, init error: Invalid procedure call or argument: 'hs.PluginFunction'
      7/9/2013 9:20:38 PM System Control Panel Immediate Script: &hs.PluginFunction("BLRussound", "", "EnableDebugLogging", Nothing)
        Is anyone able to please help, as I have been stuck for days and unable to work with the plugin. How are others doing this?
        I tried two different methods and both give errors:
        hs.Plugin('BLRussound');
        hs.PluginFunction("BLRussound", "", "SetZoneVolume", new Object(){1, 1, 75});
        Thanks!
          Thanks!
          I am trying to do this as well.
          I tried both your way and this
          hs.PluginFunction("Vista Alarm","","SendToAlarm",{"1","","FALSE"})
          Which should pass the three expected parameters
          If anyone has this working please post a working example of the proper syntax
            Hi, I recently went back to this thread to find out the syntax and also couldn't get it to work, but this way is working for me now:
            hs.RunScriptFunc( "BLRussound_Functions.vb","Set_Zone_Power","1|1|On", true, false)
            Cheers
              Cheers
              Right but how is the hs.pluginfunction() syntax look in your BLRussound_Functions.vb script?
              is it like this?
               hs.PluginFunction("Plugin Name","","Function",New Object(){"paramater1","parameter2","parameter3"})
                is it like this?
                Say I have a JS script file called: my_functions.js, which has the function below:
                function doNothing(someParams){
                //Do nothing
                You can call this from HS using this call:
                hs.RunScriptFunc( "my_functions.js","doNothing","param1|param2|param3", true, false)
                There might be other ways, but this is the only way I could find to work....
                  Hi I am trying the script as follows:
                  I get the following error:
                  Running script, script run or compile error in file: C:/Program Files (x86)/HomeSeer HS3/scripts/cal.txt1006:Expected ')' in line 1 More info: Expected ')'
                  Anythoughts? Thanks
                    Anythoughts? Thanks
                    Rename the script cal.vb and then try running that.
                    Jon
