Using the Zwave 3 plugin and 3.0.0.13 - Any attempt to add my Zwave lock fails with the security :
Done. Node 53 Added.
Synchronizing node information with HomeSeer and creating new device(s) as necessary...
Synchronize nodes finished. Number of device nodes to be created/added = 1
Device synchronization does not need to create any new SECURE devices.
Negotiating or Verifying SECURITY SCHEME for node 53
Warning: Failed to get a SECURITY SCHEME or verify the key from node 53. Device may not be added properly to HomeSeer.
Warning: The security device may have a timeout when adding to the network, bring the device close to HomeSeer and use the Add Node button to add it (remove it first)
Warning: If this device was previously added to the network, the device may need to be removed from the network and re-added.
Warning: In case the device was previously added successfully, an attempt will be made to continue the import.
Getting SECURITY class information for node 53
Error: Security class information is NOT present - cannot continue loading node 53
Device synchronization needs to create 1 Non-Secure device.
This did work previously in HS2 - Any ideas? I have the Aeon Stick right next to the lock, direct connect to the PC
