Need clarification on what version of Mono I should use
I am looking into migrating from Windows to Ubuntu 16.0.4 LTS.
The original post of this thread, which indicates what MONO components to install, is over 4 years old. I've searched through and read many forum threads on what version of MONO to install, and I can't figure out what is the proper version and components to install. The information that I see most frequently closely matches what was posted over 4 years ago, plus some differences with what's in other threads. From what I gather, I need to install (via sudo apt-get install):
mono-runtime
mono-vbnc
libmono-system-web4.0.cil
libmono-system-design4.0.cil
libmono-system-web-extensions4.0-cil
libmono-system-runtime-caching4.0-cil
Then, other threads also mentioned:
libmono-system-numerics4.0-cil sudo apt
libmono-system-xml-linq4.0-cil
mono-devel
ca-certificates-mono mono-xsp4
mono-complete
Then, in HS3 Beta Release Notes (https://forums.homeseer.com/showthread.php?t=181241), there's
a statement under changes for 3.0.0.398 saying:
"Added SSL support to web server, configure on Labs tab in setup. For Linux, MONO 5 is probably required."
Then, other threads say to use certain version of mono when migrating from Widows to Linux due to some serializing issue that was fixed in a later version.
Sigh. This shouldn't be that complicated. What's the definitive components and version that of MONO that I should install when setting up a new Ubuntu 16.0.4.3 LTS server?
Regards.
mono-runtime
mono-vbnc
mono-devel
mono-complete
Regards.
