Eliminate Light Bulbs
  • Eliminate Light Bulbs
    With 42, I've begun to look at HS3.
    Simple question: How does one eliminate the light bulb graphic on a device?
    I've removed all of the Status Graphics under that tab for the device, but the light bulb persists. I have a script supplying the graphic. This works but shows up next to the &*)^ bulb.
    OK. This is beyond annoying. Any time a device value is anywhere between 0 and 100, HS3 insists on displaying the light bulbs. This is a virtual device containing only a string, and a value. With HS2, it was a simple matter of redefining the associated graphics. I've done this but the bulbs persist along with the defined graphics.
    Is this a bug I should be reporting, or have I misunderstood something?
      Try making your device a Status Only device (from the first tab).
      Then, run your script supplying the new graphic.
        This is a known issue, it first showed up with BLRadar. But I couldn't find a ticket on it.
        Bill
          Did anyone ever find a solution to this? I don't have my own graphics, I don't want any graphics, but every value between 0-100 shows an orange light bulb.
          Author of Highpeak Plugins | SMS-Gateway Plugin | Blue Iris Plugin | Paradox (Beta) Plugin | Modbus Plugin | Yamaha Plugin
            Did you make the device virtual?
            -Rupp
              If you mean making it a "Status Only" device. Then yes, did that.
                Any solution to this problem ?
                My plugin creates new HomeSeer devices
                I explicitly clear all graphics with the command:
                hs.DeviceVGP_clearAll( deviceReference, True )
                But HomeSeer (last beta 3.0.0.71) insists on displaying light bulbs.
                stipus
