HS3 Build 3.0.0.132 Beta for HSPHONE
    Update 10/17/14
    Build 3.0.0.132 is available with some hsphone fixes. Namely settings are now saved.
    Download:
    ftp://ftp.homeseer.com/updates/Beta/..._3_0_0_132.exe
    Previous builds:
    This beta adds support for HSPhone. The support is identical to what was in HS2. It has only had limited tested, but feel free to try it and post your feedback.
    If you are not using HSPhone then please do not install this Beta.
    Changes in 3.0.0.104:
    * Fixed voicemail emailing issues
    Changes in 3.0.0.101:
    * Build # not displayed properly in .100
    * Added a missing DLL
    Changes in 3.0.0.100:
    * Squeezebox plugin should now load ok
    Changes in 3.0.0.99:
    * Fixed menus missing from some phone web pages
    * Fixed setup now installs a bunch of missing files
    Download:
    ftp://homeseer.com/updates/Beta/SetupHS3_3_0_0_104.exe
    Tested the following:
    VR works, dials by name, controls devices
    Event actions work, dial, set greeting
    It answers calls and records messages (did not test if it sends emails)
    Event triggers on/off hook work, did not test the others, but they are coded
    I did not test any scripting, most likely issues there
    Nice job Rich... trying now
    Cheers,
    Bob
      Great news,
      I will give this a go tomorrow when I have some time and report back.
      Greig
      Scripts =
      Various
        Thanks!
        Don
          HS3 Build 3.0.0.98 Beta for HSPHONE
          Nice job and looking forward to using it... Too bad I am traveling
            Great, thanks. Is the PCI Modem supported?
            Cheers
            Al
            HS 4.2.8.0: 2134 Devices 1252 Events
            Z-Wave 3.0.10.0: 133 Nodes on one Z-Net
              I did not remove the PCI modem support, so there is a chance it will work. I may not have included all the required DLL files for it, so you may need to install HS2 first.
              Cheers
              Al
                Thanks Rich, I will give it a try. HS2 is installed on the same box as my HS3 install, so all the files should be there.
                Cheers
                Al
                  ~!~Error~!~Initializing Hi-Phone: audio support driver 'hsrecord2.exe' does not exist
                  ~!~HSPhone~!~Error initializing Hi-Phone driver, possible corrupt or missing drivers, or Hi-Phone is not plugged in or powered on
                  Don
                    Hi Rich,
                    Tried it and HS Phone looks to be operating correctly for the most part. I had copied over my hsphone.ini, addressbook.xml and callers.log from HS2 and it looks like it brought all the settings over. In the addressbook screen, I would get many entries for each of the entries in the xml file, so something is not quite right there.
                    There appears to be another issue with this version of HS, it broke the Squeezebox plugin for me with the following error:
                    Warning, Cannot load EXE file (possibly missing dependencies) hspi_squeezebox.exe: Unable to load one or more of the requested types.
                     Retrieve the LoaderExceptions property for more information.
                    Warning, Error details with EXE hspi_squeezebox.exe: Method 'PlayMatch' in type 'hspi_squeezebox.HSPI_INSTANCE' from assembly 'hspi_squeezebox, Version=3.1.2.0, Culture=neutral, PublicKeyToken=null' does not have an implementation.
                    Downgrading to 3.0.0.96 got it working again. Any ideas? I'll log a bugzilla as well.
                    Al
                      Hi Rich,
                      Warning, Cannot load EXE file (possibly missing dependencies) hspi_squeezebox.exe: Unable to load one or more of the requested types. Retrieve the LoaderExceptions property for more information.Warning, Error details with EXE hspi_squeezebox.exe: Method 'PlayMatch' in type 'hspi_squeezebox.HSPI_INSTANCE' from assembly 'hspi_squeezebox, Version=3.1.2.0, Culture=neutral, PublicKeyToken=null' does not have an implementation.Warning, Error details with EXE hspi_squeezebox.exe: Method 'PlayMatch' in type 'hspi_squeezebox.HSPI_INSTANCE' from assembly 'hspi_squeezebox, Version=3.1.2.0, Culture=neutral, PublicKeyToken=null' does not have an implementation.Warning, Error details with EXE hspi_squeezebox.exe: Method 'PlayMatch' in type 'hspi_squeezebox.HSPI_INSTANCE' from assembly 'hspi_squeezebox, Version=3.1.2.0, Culture=neutral, PublicKeyToken=null' does not have an implementation.
                      Al
                      I to get this error on the Squeezebox plugin with this betta.
                      Greig.
                      Scripts =
                      Various
                        Greig.
                        Hi Greig,
                        I posted Bugzilla 1901 for this.
                        Cheers
                        Al
                          Hi Greig,
                          Cheers
                          Al
                          I added to it to to get reports. Fingers crossed its an quick easy fix.
                          Greig.
                          Scripts =
                          Various
                            Norton 360 doesn't like this new HS3.exe
                            Norton 360 deleted the HS3.exe because of SONAR.Heuristic.120.
                              It's a false positive.
                              -Rupp
