Linux 3.0.0.94 unable to check for plugins
  • Linux 3.0.0.94 unable to check for plugins
    Anyone else getting flooded with these when checking for plugins?
    Aug-10 10:12:50 PM Updater An item in the Updater is temporarily unavailable due to: Error getting response stream (Write: The authentication or decryption has failed.): SendFailure Item: http://dl.dropbox.com/u/7088674/Home...on/updates.txt
    Aug-10 10:12:50 PM Updater An item in the Updater is temporarily unavailable due to: Error getting response stream (Write: The authentication or decryption has failed.): SendFailure Item: http://dl.dropbox.com/u/7088674/Home...SS/updates.txt
    Aug-10 10:12:48 PM Updater An item in the Updater is temporarily unavailable due to: Error getting response stream (Write: The authentication or decryption has failed.): SendFailure Item: http://dl.dropbox.com/u/7088674/Home...RT/updates.txt
    Aug-10 10:12:48 PM Updater An item in the Updater is temporarily unavailable due to: Error getting response stream (Write: The authentication or decryption has failed.): SendFailure Item: http://dl.dropbox.com/u/7088674/Home...ch/updates.txt
    Aug-10 10:12:47 PM Updater An item in the Updater is temporarily unavailable due to: Error getting response stream (Write: The authentication or decryption has failed.): SendFailure Item: http://dl.dropbox.com/u/7088674/Home...ad/updates.txt
    Aug-10 10:12:47 PM Updater An item in the Updater is temporarily unavailable due to: Error getting response stream (Write: The authentication or decryption has failed.): SendFailure Item: http://dl.dropbox.com/u/7088674/Home...re/updates.txt
    Aug-10 10:12:46 PM Updater An item in the Updater is temporarily unavailable due to: Error getting response stream (Write: The authentication or decryption has failed.): SendFailure Item: http://dl.dropbox.com/u/7088674/Home...RA/updates.txt
    It's a fresh install of Linux 3.0.0.94.
    Yep, just installed HS3 under Xubuntu and have the same issue.
    Best regards,
    -Mark-
      The problem is that mono does not have any CA certs trusted by default. The easiest way to fix this is to use the default one from mozilla.
      apt-get install mono-devel
      mozroots --import
      This did is for me.
        solved for debian linux
        Thanks! solved (debian)
          no luck
            Worked like a champ, thanks!
            Best regards,
            -Mark-
              Solved the problem for me on UBUNTU/LUBUNTU 14.
              To get all the CA certs without the hassle of typing yes for each I used the command
              mozroots --import --sync
                mozroots --import fails (Debian):
                "Couldn't retrieve the file using the supplied information."
                It seem it is no longer supposed to work:
                https://github.com/KSP-CKAN/CKAN/issues/1787
                Any ideas on how to get around this?
                  Solved it!
                  Use "certmgr -m -ssl https://files.dropbox.com"
                  Answer "y" to all prompts.
                    Usually the certs are already on your machine but the mono certificate store didn't get updated with them. Next time try:
                    > sudo dpkg-reconfigure ca-certificates-mono
                    You can save the fingerache from pushing y 173 times.
                      Can't find that package?
                      Anyway, it was just 4-5 prompts.
                        I am probably being dense but when I ran that I got.....
                        Mono Certificate Manager - version 3.2.8.0
                        Manage X.509 certificates and CRL from stores.
                        Copyright 2002, 2003 Motus Technologies. Copyright 2004-2008 Novell. BSD licensed.
                        Usage: certmgr [action] [object-type] [options] store [filename]
                        or: certmgr -list object-type [options] store.............etc etc
                        What did I do wrong, I suspect I need to substitute something here ? "https://files.dropbox.com"
                          Seems I gave the wrong command, drop the "-m"... Sorry!
                          Use "certmgr -ssl https://files.dropbox.com"
