JSON
    #31
    Thanks. I'm running under Windows. I will try the \r\n tomorrow. First some sleep...
      #32
      Got it working. Before your plugin update I got sometimes 5-6 JSON strings in a row. Now it is limited to maximum two. The NewLine feed is at the end of the second JSON element, so no way to separate using the EoM string. The problem seems to occur when data is received from my smart energy meter. The plugin handling that data must be updating two references at the time.
      I have solved this by separating them by use of a regex and process them separately. It's working for now.
      Thanks for your help!
        #33
        Did some more studying. Looking at the feedback in ASCII I receive the following (my pc is setup in region the Netherlands, therefore the comma for decimals):
        DC,5,18,9210000000003,18,9110000000001
        DC,4,4003,371,4003,361
        DC,9,3,653,3,637
        At the same time I receive through the JSON plugin the following:
        {"ref":5,"status":"18,921 kWh","value":19}{"ref":4,"status":"4.003,371 kWh","value":4003.371}
        {"ref":4,"status":"4.003,371 kWh","value":4003}{"ref":9,"status":"3,637 kW","value":3.653}
        {"ref":9,"status":"3,653 kW","value":4}{"ref":5,"status":"18,921 kWh","value":18.933}
        It looks like the plugin is doubling the entries. That also seems to be the reason for the series of JSON.
        Do you have an idea what is happening here?
          #34
          Hi,
          after enabling the plugin I've got the following issues in my HS3 log:
          There occure blue stripes.
          Where is the issue ?
          Regards, Fischi
            #35
            This I have never seen when working with the plugin. Does this only happen when specific values are coming in?
              #36
              Yes,
              it only happens when specific values are coming in.
              The blue stripes are fragments from graphs of Jon00 Performance Monitor Devices.
              Regards, Fischi
                #37
                Try this for an excellent support of JSON API and REST API
                https://forums.homeseer.com/forum/li.../big5-risquare
