Creating scene event causes exception
    Hello,
    If I try to add an scene event, when I select the Z-Wave Scene Activated from the drop down I get the following error.
    Exception creating Z-Wave Trigger UI...
    Arithmetic operation resulted in an overflow.
    Homeseer: 3.0.0.97
    Z-Wave plugin: 3.0.0.187
    John
    Bugzilla time.
    -Rupp
      You may want to try HS3 .149. I just tried it and it works for me. Do you have any scenes defined?
      Cheers
      Al
      HS 4.2.8.0: 2134 Devices 1252 Events
      Z-Wave 3.0.10.0: 133 Nodes on one Z-Net
        Cheers, I try an update
          I have the same problem running zwave 3.0.1.25 and HS3 3.0.0.194
          I use Fibaro devices and i enable "scenes "on the dimmer device (changed setting 41 to 1)
          And also group 3 is associated with Homeseer.
          Is this enough actions done as a result on the question "did you enable scenes"?
            I just did a re-install of Homeseer and I am having the same problem at original poster.
            HomeSeer Version: HS3 Pro Edition 3.0.0.298 (Windows)
            Z-wave 3.0.1.87
            I had it working on my previous install. Only difference is that I am using a Aeon Labs GEN5 z-stick now, and I was using a GEN2 before.
            Any suggestions?
              I'm having this same issue. I'm brand new to Homeseer. Just purchased some Homeseer dimmers (specifically for the scene feature) and a Hometroller.
              * HS3 ZEE S2 Edition 3.0.0.297
              * Z-Wave 3.0.1.87
              Is anyone aware of a solution to this?
                For anyone who who has this problem in the future...
                This bug only shows up if you haven't created any Z-Wave scenes. Once you create at least one (done through settings of the Z-Wave plugin), you will be able to create an event as expected.
