Note: Before installing any Beta, always back up your HS3 folder so you can go back if needed. Betas may not be fully tested!
HS3 Beta version 3.0.0.528 is available for testing. See the end of this post for install instruction.
Changes from 3.0.0.497 to 3.0.0.528:
* Added support to add our new HS cameras using HS Mobile
* Fixed JSON command setdevicestatus could not set a value of 0
* Added a "compress" option to JSON command getstatus to speed up HS Mobile
* Added a new "getsessionconfig" to get permission info
* Fixed voice command "set device to # percent"
* Control Use options can not be set on status pairs (needed for future Alexa updates)
* Backup now includes html folder
* Fixed global conditions not working with plugins
* Fixed unable to add "Or If" to a global condition
* Fixed remote plugins did not display proper license
* Devices no longer display "Dim" as a status if no status pairs have been added
* Devices not longer display ON/OFF buttons by default if no control pairs are added
* Parent/Child relationships are checked on startup and issues logged as warning
* The Labs tab in setup has a new button to fix broken parent/child relationships (should fix HS Mobile issues with devices)
* Event list now has a disabled icon if an event is disabled (some users could not see the red color)
* Fixed events in HS Mobile not honoring the user access setting for users in HS
Changes from 3.0.0.478 and 3.0.0.497:
* System now creates a new database file every 10 minutes as a backup. If the main database becomes corrupt, this saved database is used automatically.
* This build is a candidate for release
Changes from 3.0.0.478 and 3.0.0.495:
* Backed out a change that attempted to fix parent/child device relationships, appeared to cause issues
* Changes to camera discovery
* When HS starts and a database issue is found in the HomeSeerData.hsd file, it then attempts to load a backup
* When logging energy data, if the device that is being logged does not exist in the energy database, it is added at the time of logging
* Event callback queue for plugins changed from 500 to 2000 entries to avoid dropping callbacks
* Fixed issue where voice recognition was not working from HSTouch
Changes from 3.0.0.470 to 3.0.0.478:
* Added check_vcmd2.vb script hook for getting Amazon Echo device ID
* Changed default plugin load setting so plugins do not load in the background
* Changed Foscam camera support to use snapshot by defaults (fixes cameras not responding)
* For HSTouch RSS feeds, now URLDecodes text
Changes from 3.0.0.460 to 3.0.0.470:
* Changes for HomeSeer Mobile
Changes from 3.0.0.459 to 3.0.0.460:
* Changes to support HomeSeer Mobile version 1.0
Changes from 3.0.0.458 to 3.0.0.459:
* Fixed cameras not displaying for HomeSeer Mobile support
Changes from 3.0.0.449 to 3.0.0.458:
* Changes for HomeSeer Mobile support
Changes from 3.0.0.445 to 3.0.0.449:
* Fixed status/graphics editor so color picker can be chosen for control type
* Fixed event action to set the color on a color bulb, not presents a color picker
Changes from 3.0.0.425 to 3.0.0.445:
* Fixed ability to set a static IP and enable WIFI on Zee S2
* Changed database saving to save less often
* Changes to JSON API for HomeSeer mobile
Install instructions:
On Windows, the installer is here:
SetupHS3_3_0_0_528.msi
HomeTroller Zee S2
551 includes changes for upgrading to HS4.
HomeTroller SEL units
550 includes changes for upgrading to HS4.
For the standard Linux, the tar file is here:
hs3_linux_3_0_0_528.tar.gz
HomeTroller Zee S2
