Originally posted by vasrc
View Post
HTML Devicestring in Textbox with no scrolling
Originally posted by rmasonjr View PostYep - just tried it here and get the same thing. You might have found a bug that only allows one $SCRIPT command.
Thanks for trying it.sigpic
A founder member of "The HA Pioneer Group" otherwise known as the "Old farts club!"
Originally posted by vasrc View PostJust mark Marque function as True, but I would think 3 separate scrolling boxes would be hard on the eyeballs
Z
I would like a single scrolling ling reporting all the temperatures. I already have three static text box's.sigpic
Doesn't look like that's possible with the HStouch internal commands, seems it's only going to let you make one variable call at a time?
It could be done with a script that builds the string for you perhaps using similar calls you already tried. Can't say I've tried to display the results of a call to a script, I'll have to check that out, sounds useful..
Currently it's time for a Guinness FES though
ZLast edited by vasrc; July 17, 2013, 09:58 PM.
I think I would be writing a script to do it personally...just to generate the line in a device string and status track it.
Originally posted by vasrc View PostDoesn't look like that's possible with the HStouch internal commands, seems it's only going to let you make one variable call at a time?
Zsigpic
Scrolling Screen
I just found this thread and find it a bit over my head. In Designer, is it possible to create a scrolling screen other than the very structured format offered by the List Box? I have a layout that I love, but need another row.HS4Pro on Windows 10
One install with 2 Ethernet Z-nets
2nd install with 1 Ethernet Z-net
300 devices, 250 events, 8 scripts
6 CT-100 tstats
Serial IT-100 interface to DSC Panel with 8 wired zones
18 Fortrezz water sensors & two valve controls
