Problem with showing graphs. Cache related?
    In homeseer I am making graphs with the Device History plugin via events. This yields png files in the /usr/local/HomeSeer/html/DeviceHistory/images/chart directory.
    Within HSTouch Designer I show the graphs in a graphic element with a URL to the png file in the ImageURLNormal field. The graph is visible now in the element.
    After deploying the project to my Android phone I can see the graph without a problem. But, if I remake the graph with the event than I always see the old graph in HSTouch although the new graph correctly shows up in the chart directory. After renewing the graph several times it keeps showing the first graph.
    I observe that when I do a 'close all apps' on my Android phone than the latest figure is shown in HSTouch. Could this be related to a kind of a clear cache problem? I cannot find any possibility to set this.
    I also observe that the same is happening on my iPad that is why I think there must be something wrong in HSTouch Designer.
    HomeSeer HS4 is running on a RaspberryPi4 with Raspbian Buster.
    Any help appreciated.
    -- Cor --
    I believe you are correct that it is a problem with the image being cached. I've found that if I select 'IsVideo' and choose a reasonable refresh rate (that can usually be quite slow) the image updates normally.
    Click image for larger version  Name:	IsVideo.png Views:	0 Size:	3.6 KB ID:	1432739
      I set up an html file for each graph and then move each individual html file to a unique html file name. I have a script that moves the file. Always updates. The HTML files are all the same except for the img src filename. I use this for temperature, memory usage and weather files.
      <html lang="en">
      <head><META HTTP-EQUIV=Refresh CONTENT=600></head>
      <body bgcolor="MidnightBlue" leftmargin="0" topmargin="0" marginwidth="0" marginheight="0">
      <img src="http://192.168.1.135/opt/HomeSeer/Data/TemperatureLog/Device3285.png" height="100%" width="100%"></img>
      </body>
      </html>
      A snippet showing the setup in hstouch.
Name:	Screenshot from 2020-11-12 09-12-19.png
      '12/23/2019 ScrollTemp.vb
      'Script to scroll through static pictures and write html file to unique filename.
      'jlg 4-20-2020 Add Device 743 to list
      IMPORTS System.IO
      IMPORTS System.Net
      IMPORTS System.Threading
      Sub Main(ByVal Parm As String) 'There are 0 parameters
      Dim sPath, sDisplayFile, Counter, Source, Destination As String
      Dim sFile(19) As String
      Dim dCounter As Double
      Dim iCnt, iMax, iIncCnt As Integer
      iMax = 19 'Set the maximum number of maps
      Counter = "TemperatureCntr" 'Created Counter
      'set the files and pathname for maps
      sPath = "/opt/HomeSeer/html/" 'The Path Name to the files
      sFile(0) = "Chart486.html"
      sFile(1) = "Chart492.html"
      sFile(2) = "Chart497.html"
      sFile(3) = "Chart688.html"
      sFile(4) = "Chart690.html"
      sFile(5) = "Chart691.html"
      sFile(6) = "Chart695.html"
      sFile(7) = "Chart706.html"
      sFile(8) = "Chart3285.html"
      sFile(9) = "Chart720.html" 'was 3374 - rescan set the new ref id to 720
      sFile(10)= "Chart3409.html"
      sFile(11)= "Chart3497.html"
      sFile(12)= "Chart3618.html"
      sFile(13)= "Chart3679.html"
      sFile(14)= "Chart3683.html"
      sFile(15)= "Chart3687.html"
      sFile(16)= "Chart3691.html"
      sFile(17)= "Chart3736.html"
      sFile(18)= "Chart3787.html"
      sFile(19)= "Chart3837.html"
      'sFile(20)= "Chart743.html"
      sDisplayFile= "Temperature.html" 'the file to use for display
      dCounter = hs.CounterValue(Counter) 'Get the Map Counter Value
      iCnt = CInt(dCounter) ' Set the double to an integer
      'Make the list a loop and set the Counter correctly
      If iCnt < 0 Then 'Went through the floor value so set to ceiling value.
      hs.CounterReset(Counter)
      For iIncCnt = 1 To iMax+1
      hs.CounterIncrement(Counter)
      Next
      iCnt = iMax
      End If
      If iCnt > iMax Then 'Went through the ceiling value so set to the floor value
      iCnt = 0
      End If
      Source = sPath & sFile(iCnt)
      Destination = sPath & sDisplayFile
      'Overwrite or create the file that will be displayed.
      System.IO.File.Copy(Source, Destination, True)
      End Sub
      I recognize that this is convoluted, however it has been solid for the last year.
        Thank you both for the information. It turns out that the solution of Uncle Michael works very nice.
        -- Cor --
