I just bought a new micro-pc to install HS4 Pro (when it is released). My question is will HS4 Install in a different directory as HS3? The reason I'm asking is because since we have no idea when HS4 is going to be released, I don't want my new computer to collect dust until then. I'd like to install HS3 on my new computer but I don't want to insure my HS4 install is clean and without any residual HS3 components that may negatively impact new install.
will HS4 install in a different directory as HS3?
Originally posted by upstatemike View Post
So what happens exactly if you start HS3 and HS4 at the same time on the same PC?
Originally posted by jon00 View Post
If you started them together with no plugins or connected hardware, they would both run fine, As soon as you add any plugins or connect hardware requiring serial/usb ports etc, the first one started would win. This would include remote plugins.
Originally posted by joegr View Post
So, would it be possible to run H3 with no plugins on the same machine as HS4 with plugins? I'm looking for a way to retain HSPhone.
Originally posted by drhtmal View Post
I know that. Just pointing out that if you were wanting to do a stock install of HS4 on your HS3 machine it would be a problem unless the ports were changed.
The most important thing to me is if I can run HS3 then stop it and bring up HS4 with the same HS3 configuration. Until I know that HS4 is stable I want to be able to run HS3 normally then bring up HS4 for some testing using the same configuration. In addition I want to restore my HS3 configuration back to HS4 ant any time.
Once done testing is done shutdown HS4 and bring up HS3 to put the house back to normal. Once I've run everything for a while then I'll feel good about running HS4.HomeSeer Version: HS3 Standard Edition 3.0.0.548
Originally posted by upstatemike View PostStill not clear why it would be a problem. Using HSPhone as an example: If there are no plugins installed in HS3 then the only shared resources would be the audio card right? Add a USB audio card just for HS3 to use and it seems like there would be no overlap so no point of conflict.
Well, that's a shame. I need HSPhone still and probably will for at least a few more years. I don't like the idea of having yet another PC running all the time.
I guess maybe I could run HS3 on a PI? Anyway, this is going to be like the move from HS2 to HS3 was for me. I'll wait till HS3 plugin support is gone and I can't do what I need to do with it before I switch to HS4.
- Likes 1
