Proper HomeKit Support
    #31
    I can confirm I have all my lights set as "lightbulbs" but I happily tell my Apple Watch to "Set Living Room Lights To 30%" and it happens in a split of a second 👍
      #32
      I have been slowly adding accessories and now have 16 HS4 devices working with HomeBridge. But they have disappeared in the HS4 plugin. When I restart homebridge/plugin everything works but the accessories are not showing in the plugin?
      Steve
        #33
        Now homebridge will not restart!
          #34
          Ok, I restored my config file from yesterday and now everything is working again. Homebridge restarted and my accessories(devices) are now back.
          Steve
            #35
            Hi guys,
            I have achieved to get Homebridge up and running and I can add lights, switches etc. It looks really promising
            However, I cannot figure out how to add thermostats.
            I am using the GUI and have tried to add the "ref" of the root device in the simple device setup. (I.e. when I press the root device in HS I can see the "ref=XXX" in the url and that is the number I use), however this does not work. I have also tried to insert the ref of the child device for e.g. setpoint. I also tried to insert the Z-wave node number.
            I have also tried the advanced setup adding the "ref" of the root device and the "ref" of the child devices but that does not work either.
            I would be really appreciated if somebody could guide on this i.e. what information do I need to pick from HS and insert into homebridge?
              #36
              Originally posted by 8200 View Post
              Hi guys,
              I have a Trane thermostat. My config.json has:
              "type": "Thermostat",
              "name": "Living Room Thermostat",
              "ref": 599,
              "heatingSetpointRef": 604,
              "coolingSetpointRef": 605,
              "controlRef": 602,
              "stateRef": 603
              Where:
              controlRef is the reference for the thermostat's mode (e.g. Auto, Off, Heat, Cool, etc.)
              stateRef is the reference for the operating state (idle, Heating, Cooling, etc.).
                #37
                Thanks, that is very helpful and I suceeded in adding thermostats (Eurotronic) with the ref pointing to the device showing the temperature. However, I have a few Danfoss thermostats which do not have a devices showing current temperature or mode but only root devices, battery and setpoint. Those I have not figured out yet...
                  #38
                  I would like to share my experience with HomeKit/HomeBridge/HomeBridge-HomeSeer4. It works. It's a bit ugly to get/keep the config.json straight, but Homebridge UI makes it relatively straight forward. I have deployed HomeBridge on a Raspberry PI, as the windows-based product is flakey at best. Yes, I'd prefer a native PI, but this is a workable solution.
                    #39
                    How dare you call my ugly baby ugly.
                      #40
                      I’m using HOOBS on a rpi with the HS3 HS4 plugin. It’s fantastic. Very easy to setup because of the plug-in.
                      If you are asking for native HomeKit, don’t. This is probably better.
                      Sent from my iPhone using Tapatalk Pro
                      _______________________________________________
                      HS3 : HSpro (3.0.0.460) on Win2012 (vm on ESXi)
                      Plugins: HSTouch, UPBSpud, Kinect, Nest, IFTTT, DirecTV, EasyTrigger, Imperihome, Zwave, RFXcom, UltraMon3, UltraWeatherBug3, UltraGCIR3, UltraLog3, UltraPioneer, PHLocation, Pushover, Pushalot, MCSSPrinklers S, JowiHue
                      Jon00 Plugins: Bluetooth Proximity, Performance Monitor, DB Chart, Links
                        #41
                        Can you elaborate a bit on how this works? Ease of use? Etc. I can't find a plugin anywhere.
                        rjh Are there any plans for HomeKit support?
                          #42
                          Right here : https://support.hoobs.org/docs/5e875b610ab68b0344e872c5
                          And here : https://homebridge.io/
                          The plug-ins https://github.com/jvmahon/Homebridge-HomeSeer4
                          Eman
                            #43
                            Wow never saw this before. Does this solve the "sorry your device isn't responding". I get this every once in a while.
                              #44
                              I set up on NAS but don't use. I use Home Remote and HStouch but if I ever find the need for it then it's there.
                              Eman.
                                #45
                                I am running HS3, homebridge and jvm 's plugin on windows. I have dozens of devices in homebridge config. This stuff just works, I don't touch it for months...
