I can confirm I have all my lights set as "lightbulbs" but I happily tell my Apple Watch to "Set Living Room Lights To 30%" and it happens in a split of a second đź‘Ť
Proper HomeKit Support
I have been slowly adding accessories and now have 16 HS4 devices working with HomeBridge. But they have disappeared in the HS4 plugin. When I restart homebridge/plugin everything works but the accessories are not showing in the plugin?
SteveHomeSeer Version: HS3 Pro Edition 3.0.0.368, Operating System: Microsoft Windows 10 - Home, Number of Devices: 373, Number of Events: 666, Enabled Plug-Ins
Now homebridge will not restart!
Ok, I restored my config file from yesterday and now everything is working again. Homebridge restarted and my accessories(devices) are now back.
Steve
Guest
Hi guys,
I have achieved to get Homebridge up and running and I can add lights, switches etc. It looks really promising
However, I cannot figure out how to add thermostats.
I am using the GUI and have tried to add the "ref" of the root device in the simple device setup. (I.e. when I press the root device in HS I can see the "ref=XXX" in the url and that is the number I use), however this does not work. I have also tried to insert the ref of the child device for e.g. setpoint. I also tried to insert the Z-wave node number.
I have also tried the advanced setup adding the "ref" of the root device and the "ref" of the child devices but that does not work either.
I would be really appreciated if somebody could guide on this i.e. what information do I need to pick from HS and insert into homebridge?
"type": "Thermostat",
"name": "Living Room Thermostat",
"ref": 599,
"heatingSetpointRef": 604,
"coolingSetpointRef": 605,
"controlRef": 602,
"stateRef": 603
Where:
controlRef is the reference for the thermostat's mode (e.g. Auto, Off, Heat, Cool, etc.)
stateRef is the reference for the operating state (idle, Heating, Cooling, etc.).
Guest
Thanks, that is very helpful and I suceeded in adding thermostats (Eurotronic) with the ref pointing to the device showing the temperature. However, I have a few Danfoss thermostats which do not have a devices showing current temperature or mode but only root devices, battery and setpoint. Those I have not figured out yet...
I would like to share my experience with HomeKit/HomeBridge/HomeBridge-HomeSeer4. It works. It's a bit ugly to get/keep the config.json straight, but Homebridge UI makes it relatively straight forward. I have deployed HomeBridge on a Raspberry PI, as the windows-based product is flakey at best. Yes, I'd prefer a native PI, but this is a workable solution.
Originally posted by madmellow View PostI would like to share my experience with HomeKit/HomeBridge/HomeBridge-HomeSeer4. It works. It's a bit ugly to get/keep the config.json straight, but Homebridge UI makes it relatively straight forward. I have deployed HomeBridge on a Raspberry PI, as the windows-based product is flakey at best. Yes, I'd prefer a native PI, but this is a workable solution.
- Likes 3
I’m using HOOBS on a rpi with the HS3 HS4 plugin. It’s fantastic. Very easy to setup because of the plug-in.
If you are asking for native HomeKit, don’t. This is probably better.
Sent from my iPhone using Tapatalk Pro_______________________________________________
HS3 : HSpro (3.0.0.460) on Win2012 (vm on ESXi)
Plugins: HSTouch, UPBSpud, Kinect, Nest, IFTTT, DirecTV, EasyTrigger, Imperihome, Zwave, RFXcom, UltraMon3, UltraWeatherBug3, UltraGCIR3, UltraLog3, UltraPioneer, PHLocation, Pushover, Pushalot, MCSSPrinklers S, JowiHue
Jon00 Plugins: Bluetooth Proximity, Performance Monitor, DB Chart, Links
Originally posted by jlrichar View PostI’m using HOOBS on a rpi with the HS3 HS4 plugin. It’s fantastic. Very easy to setup because of the plug-in.
rjh Are there any plans for HomeKit support?
And here : https://homebridge.io/
The plug-ins https://github.com/jvmahon/Homebridge-HomeSeer4
Eman
Originally posted by Eman View Post
Right here : https://support.hoobs.org/docs/5e875b610ab68b0344e872c5
Eman
Originally posted by freeon View Post
Wow never saw this before. Does this solve the "sorry your device isn't responding". I get this every once in a while.
Eman.TinkerLand : Life's Choices,"No One Size Fits All"
Originally posted by madmellow View Postas the windows-based product is flakey at best. Yes, I'd prefer a native PI, but this is a workable solution.
- Likes 1
