HS4 Events live across Reboots?
  • HS4 Events live across Reboots?
    In HS3 a design gap (major IMO) is that an event will not live across reboots. Has this been fixed in HS4?
    See screenshot for example... if the PC reboots at 4am (so it missed one of the 'off' cycles) the event will never turn off the device... thus the device runs forever, until you manually turn it off. It never triggers again at 5am +1 second.
    Have you investigated if power failure recovery might resolve the issue.
      mine looks like this...
        Do you have power failure recovery enabled for the event?
          Thank you, I did not... thought I did. Spaced that option!
            Does this really works?
            I saw something similar with the trigger ‘’ has been this value for exactly’’
              You could re-write this into two separate events.. one turns on the pump at specified time, the other turn it off whenever it has been on for longer than 30 seconds.
